RTOS not working?
CaFFeiNe
RTOS not working?
PostPosted: Mon Mar 06, 2006 1:53 pm     Reply with quote
Example code in CCS
Proteus Isis simulation capture
as you see RTOS example code didn't work or I couldn't
do you have any idea?
thanks
treitmey
PostPosted: Mon Mar 06, 2006 2:04 pm     Reply with quote
I had that example working with a 452 @40MHz outputing to a debug window.
Check your hardware. The RTS/CTS is just hanging there. Is that correct??
PostPosted: Mon Mar 06, 2006 5:44 pm     Reply with quote
I don't see settings for the fuse settings. Add at the minimum:
#fuses HS, NOLVP, NOWDT
kel
virtual tool looks kind of cool
PostPosted: Tue Mar 07, 2006 7:06 am     Reply with quote
Is your simulator(virtual tool) free.if it's could you please post the link for downloading.I kind of like.. Shocked
KenMacfarlane
Proteus doesn't support source level debug for CCS C
PostPosted: Tue Mar 07, 2006 11:38 am     Reply with quote
From the Proteus website, on supported compilers...
the limitations of the COD symbolic debug data format mean that the VSM debugging support for this product is limited to stepping through the machine code and watching specific memory locations. Source level stepping and variable display are not supported.
Pity...the environment looks really cool!
Perhaps that's why you can't run the RTOS -how do you run single tasking code?
PostPosted: Tue Mar 07, 2006 2:07 pm     Reply with quote
I did this but still it doesn't work
anybody work this example?
(sorry for my english)
CaFFeiNe
PostPosted: Tue Mar 07, 2006 2:08 pm     Reply with quote
rberek
PostPosted: Tue Mar 07, 2006 2:19 pm     Reply with quote
The Proteus environment still works really well for CCS compiled code. I use it all the time. Writing the code in MPLAB C18 will give you more debugging capability, but I've designed some small boards with it and done all the simulation with CCS, and caught alot of bugs. The boards pretty much work right the first time.
And for kel's benefit, it is not free.
The difference between genius and stupidity is that genius has its limits...
PostPosted: Tue Mar 07, 2006 3:12 pm     Reply with quote
Without these fuses your clock wasn't running, which makes me wonder ... Is this the first program you are running on this board?
Have you tried a simple application, for example just blinking a led?
The PIC18F452 has no internal oscillator, but in your schematic I don't see anything connected to pin 13 and/or 14.... ???
CaFFeiNe
PostPosted: Wed Mar 08, 2006 11:43 am     Reply with quote
is there anybody have a working example for RTOS in CCS ?
if you have, could you upload to rapid please?
thanks
PostPosted: Wed Mar 08, 2006 1:10 pm     Reply with quote
Is there anybody have a working example for RTOS in CCS ?
One reason for limited responses is that CCS only gives the RTOS
to people who buy PCW or PCWH. They don't give it with the
command line compilers such as PCM or PCH. You get the example
files with those compilers, but the #use RTOS() statement gives a
compiler error if you try to use it.
So you're limited to a smaller number of people who can reply to
your questions.
PostPosted: Mon Jun 19, 2006 3:16 pm     Reply with quote
I have the same problem with RTOS and proteus....
If someone have the solution for it, please let me know
