read program memory problem
tomH
PostPosted: Thu Jun 15, 2006 2:54 pm     Reply with quote
Hi, I'm trying to read program memory of 16F877 half
way through the program memory where values are all
0xFF. I'm using the line
read_program_memory(0x1000,&g_ucTestRead[0],2);
I seem to be reading back random values. Am I
misunderstanding how to use this function?
Thank's Tom
PostPosted: Thu Jun 15, 2006 3:45 pm     Reply with quote
I made the test program below, and compiled it with PCM vs. 3.249.
It worked OK. It displayed the following output:
ff 3f
That's the LSB and the MSB of the program word at ROM address 0x1000.
I used the ICD2 to erase the PIC before I programmed it, so I know
that it will have 0x3FFF in all erased locations. Is it possible that you
have old code left in most of your PIC ? Try erasing it first. Then
run the test program.
#include <16F877.H>
#fuses XT, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
int8 g_ucTestRead[10];
read_program_memory(0x1000, &g_ucTestRead[0], 2);
printf("%x %x \n\r", g_ucTestRead[0], g_ucTestRead[1]);
