bsearch
hadeelqasaimeh
bsearch
PostPosted: Thu Jun 15, 2006 3:56 am     Reply with quote
hi all
any body know how do this instruction work?
Syntax:
 ip = bsearch
(&key, base, num, width, compare)
Parameters:
 key: Object to search for
base: Pointer to array of search data
num: Number of elements in search data
width: Width of elements in search data
compare: Function that compares two elements in search data
can i use this to search for a bit through a string?
i use pic c compiler v3.249
thank you.
PostPosted: Thu Jun 15, 2006 11:40 am     Reply with quote
If you can't find the answer in the CCS manual or by searching this
board, just use http://www.google.com
C is a very well known language. There are lots of examples on
all commonly used C functions, with source code.
Use these keywords in Google: bsearch example
