Hernán Guest
Problem using 2 rs232 ports on 18f8722 |
Posted: Mon Jun 12, 2006 5:00 am |
I'm using 2 rs232 ports with the PIC18f8722 in order to communicate with a PC and a GSM module. The thing is both communications seem to work fine in the beginning, but as soon as I send some information to the PC, the communication with the module starts to fail. I still can send info to the module, but I can`t receive from it. Using the very same code but not transmitting first to the PC the program works, and a very similar program communicating to a WiFi module instead of the GSM one works too (including the PC part).
Is there any issue about using both rs232 that I should know of? did anyone have this problem, or alike, before?
Thank you. |
Mark
Posted: Mon Jun 12, 2006 8:07 am |
Be sure to include "ERRORS" in you #use RS232 statement. |
ALFA 705
Posted: Mon Jun 12, 2006 9:06 am |
I had SERIOUS problems with 18F8722 using the two UARTS at same time.
An Errata about that is showed on www.microchip.com
I hope this help you. If you need further detatais....
ALFA 705 |
Hernán Guest
Posted: Wed Jun 14, 2006 1:26 am |
Thank you for the replies.
ALFA, I've scanned throught the erratas concerning 18f8722 in the microchip webpage, but were unable to find the one relating to the problem about using both UARTs at the same time, could you please give me some more details about it?
Thank you again. |
ALFA 705
Posted: Thu Jun 15, 2006 10:32 am |
Hernan,
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010327
This errata says "...when performing BACK-TO-BACK transmision..."
Yes, this errata only mention for 9 bits but you have believe me, in 8bits fails too under some conditions.
I receive from one EUSART and send to other the EUSART. In some cases (random) the PIC inserts an extra "0x00". Microchip say me that is an ERRATA.
Silicon revison is scheduled for next year 2007 !!!!!! Incredible.
Sorry for my Englsh.
ALFA 705 |
