Storing a stream on a variable
PostPosted: Tue Jun 06, 2006 5:27 am     Reply with quote
I am attempting interface of a weigand reader to my pic. My question is, how can i store an incoming pulse stream of highs and lows on a pin and properly set my variable. For instance as a certain pin goes low i want my variable to streams bit value. Example data variable is 00000000 then as pulses come in for 1 and 0 i want to be able to store the proper pulse to the variables bit location. For instance if i receive four pulses for ones and four pulses for zeros my variable must store 11110000. I hope i make any sense.
Thanks!
Christophe
PostPosted: Tue Jun 06, 2006 5:55 am     Reply with quote
This smells like timers.
At what speed is the pulse train coming?
You can read a pin every X time in an interrupt.
then you have to read the pin and set a bit of an 8 bit variable.
int8 pulses , j = 0;
timer0_isr()
if ( input (PIN_X0))
     bit_set ( pulses, j )
     bit_clear (pulses , j )
j++;
if ( j = = 7 )
 j = 0;
