pcf2113 i2c lcd driver
mds
PostPosted: Wed May 31, 2006 5:32 pm     Reply with quote
Anybody had any experience with the pcf2113 lcd driver from philips?
Im having a few problems with a purchased module which came with little data.
http://mec-symonds.eng.monash.edu.au/twiki/bin/view/Saqqara/LcdModulePcf2113
Main problems:
1) there are some "icons" not apart of the matrix make up which seem, once the display is initialised, are permanently on. ie I cant find their address
2)The data sheet doesn't explain how to access the other character sets.
thanks
mds
PostPosted: Wed May 31, 2006 5:59 pm     Reply with quote
solved number 2
missed a line in the data book
the suffx x in the pcf2113x denotes which character set is hard coded.
Using some code I deduced I have the A character set.
vibrasys
PostPosted: Fri Jun 02, 2006 4:24 pm     Reply with quote
Here's a lcd driver: PCF2113 code example - http://sandiding.tripod.com/phlcd.html
;* Lcd icon sets off *
call iict
movlw 0x74
call act
movlw 0x80 ; Co=1, RS=0 just one next command byte
call act
movlw 0x40 ; set CGRAM for icons
call act
movlw 0x40 ; Co=0, RS=1, set instruction register for multiple next data bytes
call act
movlw 0x00 ; erase icons sequence
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
movlw 0x00
call act
call iicp ; i2c stop
(*act-> iic data transmission routine,
movlw 0x00-----
call act -----same as i2c_write(0x00); )
Best Regards
