16F690 PWM setup
GhostofK
16F690 PWM setup
PostPosted: Fri Jun 02, 2006 7:52 pm     Reply with quote
Hi, I'm trying to get the PWM of my PIC16F690 working. Unfortunately, no matter what I do, I can't seem to make the thing output what I want. Ideally, I want to have the CCP1 pin always output a constant 40Khz square wave, 50% duty cycle. However, I always get a constant voltage out for some reason. I've been looking at the provided examples from CCS and I've been poking aroun this forum too, but nothing seems to work. Can someone have a quick look at my code and tell me what I'm doing wrong? The compiler version is 3.243 btw.
Thanks for any help!
#include <16F690.h>
void main(){
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x00);
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_1, 24, 1);
set_pwm1_duty(20);
PostPosted: Fri Jun 02, 2006 8:09 pm     Reply with quote
See the example that I've posted in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729
Note the things in that example that are missing from your code:
It has a #fuses statement, and a while(1) statement at the end.
Note the things that are not needed: set_tris_x() statements.
That example shows how to setup two PWMs, but it is still
applicable to your situation.
GhostofK
PostPosted: Fri Jun 02, 2006 8:36 pm     Reply with quote
AWESOME. It works! Thanks!
