Can this faster / with less ROM
Christophe
PostPosted: Thu Jun 01, 2006 6:20 am     Reply with quote
I read that printf instructions use a lot of ROM.
I use a lot of these:
printf("%c%S%c", COMMANDO_BYTE, WAKE_COMMANDO,0);
Can this be improved?
PostPosted: Thu Jun 01, 2006 7:22 am     Reply with quote
Are the bytes constants or variables?.
There should not be a lot in it for a late compiler (the optimiser is fairly 'smart' for this type of simple operation). Where printf, drinks memory, is first, if you do 'simple' numeric outputs, which themselves will involve a lot of divisions etc., and even worse, when you start dealing with float values.The problem is that an understanding of just how much actual 'work' is involved in a tiny statement, like:
printf("%5.2f/n",val);
is often lacking...
Looking at your example, simply changing to:
printf("%c%S\0", COMMANDO_BYTE, WAKE_COMMANDO);
Will save typically eight bytes.
Christophe
PostPosted: Thu Jun 01, 2006 8:07 am     Reply with quote
constants
//Commando's
#define TOETS_COMMANDO "KEYS"
#define COMMANDO_BYTE 0xAA
#define DRUK_COMMANDO "PRES"
#define BATTERIJ_COMMANDO "BATT"
#define ADAPTER_COMMANDO "ADAP"
#define WAKE_COMMANDO "WAKE"
#define SLEEP_COMMANDO "SLEE"
#define START_LADEN_COMMANDO "LDNG"
#define EINDE_LADEN_COMMANDO "FULL"
#define ADAPTER_IN_COMMANDO "ADIN"
#define ADAPTER_UIT_COMMANDO "ADUT"
#define ADAPTER_STATUS "ADAS"
#define LAAD_STATUS "LAAD"
#define BRAILLE_COMMANDO "BRAI"
#define BRAILLE_CLEAR "BRCL"
#define BRAILLE_SLEEP "BRSL"
#define BRAILLE_WAKE "BRWA"
#define LADEN_UIT "LDOF"
#define LADEN_AAN "LDON"
#define MAX1797_AAN "5VON"
#define MAX1797_UIT "5VOF"
#define BOOT_OK "BOOT"
#define UITZETTEN_E3 "E3OF"
#define BOOT_OK_COMMANDO "BTOK"
#define UIT_TIMER "OFTI"
#define TOETSKLIK "KLIK"
Christophe
PostPosted: Thu Jun 01, 2006 8:22 am     Reply with quote
is often lacking...
With that, the last '0' is not being sent. (And I need to..)
PostPosted: Thu Jun 01, 2006 9:49 am     Reply with quote
Yes, you cannot send a trailing '0' this way (the only character you can't), since it is seen as the 'end' of the printf string. The other constants can be, but I doubt if you will save anything. The compiler is bright enough to know that with constants, it just has to load the value, and send it.
If you only have to send a couple of constant values, you are not going to save anything. If the list is a lot longer, there are other tricks that can help (the overhead of fetching a list from ROM, is probably equivalent to about five values - above this length, this will be better, but below this length it'll be worse, so using this technique only becomes worthwhile for longer messages).
libor
PostPosted: Thu Jun 01, 2006 10:13 am     Reply with quote
Cristophe, I see all your commandos are four-letter words (no pun intended :-) , so you can perhaps organize them into a lookup table, and make a custom printf routine, that would take only an index into this table as a parameter.
Christophe
PostPosted: Fri Jun 02, 2006 6:43 am     Reply with quote
libor,
could you make a small example? I don't understand what you mean.
thx for the input all
