Accessing Digital I/O from within a for loop
topfuel
PostPosted: Fri Jun 02, 2006 6:22 am     Reply with quote
I am trying to read 5 digital I/O pins in a for loop.
Each time through the loop I want to read 1 dig i/o pin.
i.e.
pass 1 read PB0
pass 2 read PC3
pass 3 read PA3
etc.
I am using CCS C compiler and they have an input() function that uses a constant for each I/O pin #
In the header file they have each i/o pin defined.
I tried using a data table
BYTE CONST INPUT_PINS[6]= {PIN_B0,PIN_C2,PIN_B1,PIN_C4,PIN_C3};
in the loop I used the following
if (!input(INPUT_PINS[i]))
but the compiler complains that "Expression must evaluate to a constant"
What is the proper way to do this?
PostPosted: Fri Jun 02, 2006 7:26 am     Reply with quote
The same question was asked yesterday.
For a replacement function accepting variable pin numbers see:
PIC16: http://www.ccsinfo.com/forum/viewtopic.php?t=25280
PIC18: http://www.ccsinfo.com/forum/viewtopic.php?t=25591
Christophe
PostPosted: Fri Jun 02, 2006 7:30 am     Reply with quote
Now that was exactly my problem yesterday. You will find solution + implementation here:
http://www.ccsinfo.com/forum/viewtopic.php?t=27192
rgds
