EEPROM Help needed, please
crystal_lattice
PostPosted: Tue Jun 13, 2006 12:16 pm     Reply with quote
Hi, im using a 16f877 pic with a ds1302 RTC.
I want to make a basic datalogger that logs the date & time and a value, say a 16bit value. Using 93LC66 as external eeprom. My plan is to convert the date & time to a 32bit value to save space. my problem is that the two values differ in size, will that complicate the eeprom write?
I am a beginner so take it easy on me.
1) Does any one have a good explanation of how the eeprom is structured so that i can visualize it so i can understand it better? I am new to this eeprom memory and a good explanation will help me alot.
2) Does anyone have a working example of a program that uses the 93LC66 or the 24LC00, just so i can check if all my hardware is working, then i can modify/ experiment in my own time. As in somthing i can take 'as is' and compile it and it works.
Thanx in advance!
Mark
Re: EEPROM Help needed, please
PostPosted: Tue Jun 13, 2006 12:53 pm     Reply with quote
No. You will only write 8 bits anyways.
Yes. It is called a datasheet.
The drivers are in the drivers directly. There are plenty of examples in the examples directory as well as tons of info on this forum.
