AcquaVx
Sending hexa messages |
Posted: Mon Jun 12, 2006 10:41 am |
Hi all !
My question is certainly pretty stupid.
I'm using CCS 3.242 and a PIC18F2520.
The microcontroller is communicating with a WiFi device and a RFID device. The WiFi works fine.
Regarding the RFID, I have to send a particular message to tell him "Send me the ID on any tags you may find".
The request packet sent to the RFID device is composed of 1 even parity bit, 1 stop bit, 8 bits of data at 9600 bps. Therefore :
Code: | #use rs232(baud=9600,parity=E,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=RFID) //UART PIC à RFID |
The request packet I'd like to send is :
0x05+0xFF+0xAC+0x80+0xD6
I'm trying to send it to the RFID device. How should I do it ? I've tried :
Code: | enum trame_type
autoanswer = 0x05+0xFF+0xAC+0x80+0xD6, // Réponse automatique du lecteur RFID vers le microcontrôleur
period = 0x06+0xFF+0xAD+0x01+0x00+0x55, // Période d'activation du lecteur RFID
a=0x05,
b=0xFF,
c=0xAC,
d=0x80,
e=0xD6,
and :
:: puts("0x05+0xFF+0xAC+0x80+0xD6",RFID);
:: fputs(autoanswer,RFID);
:: fprintf (RFID, "0x05+0xFF+0xAC+0x80+0xD6");
:: fprintf (RFID, autoanswer);
and finally :
Code: | char temp_TTL[]="";
strcpy(temp_TTL,a);
strcat(temp_TTL,b);
strcat(temp_TTL,c);
strcat(temp_TTL,d);
strcat(temp_TTL,e);
fputs(temp_TTL,RFID);
None of this works.
Thank you for your suggestions, if any : )
Bye |
newguy
Posted: Mon Jun 12, 2006 10:52 am |
I'm about 99% sure about this:
Code: | putc(0x05);
putc(0xff);
putc(0xac);
putc(0x80);
putc(0xd6); |
The 1% unsure being that I can't remember using putc() before. Something to try anyway. |
Humberto
Posted: Mon Jun 12, 2006 11:53 am |
fprintf (RFID, "%x%x%x%x%x",0x05,0xFF,0xAC,0x80,0xD6);
fprintf (RFID, "%x%x%x%x%x%x",0x06,0xFF,0xAD,0x01,0x00,0x55);
or if the '+' is needed:
fprintf (RFID, "%x+%x+%x+%x+%x",0x05,0xFF,0xAC,0x80,0xD6);
fprintf (RFID, "%x+%x+%x+%x+%x+%x",0x06,0xFF,0xAD,0x01,0x00,0x55);
or
fputc(0x05, RFID); fputc('+', RFID);
fputc(0xFF, RFID); fputc('+', RFID);
fputc(0xAC, RFID); fputc('+', RFID);
Humberto |
treitmey
Posted: Mon Jun 12, 2006 12:36 pm |
I thought he might need to send the hex
fprintf (RFID, "%c%c%c%c%c",0x05,0xFF,0xAC,0x80,0xD6);
or the putc will work |
AcquaVx
Posted: Wed Jun 14, 2006 12:56 am |
Thank you guys. I'm getting results.
Enjoy the day : ) |
