smxabi
It sound very low |
Posted: Wed May 31, 2006 10:08 am |
Hi
This is my favorite site to inquire all my troubles.
Well, I compiled and tested the exercise EX_SQWC from CCS examples: Code: |
#include <16F877A.h>
I am using the proto 16F877A from CCS
printf("Press any key to begin\n\r");
getc();
printf("1 khz signal activated\n\r");
while (TRUE) {
output_high(PIN_B0);
delay_us(500);
output_low(PIN_B0);
delay_us(500);
when I conect a loudspeaker from an old mobile phone sound, but very low. In the phone sound quite right. The loudspeaker is SD153B and finding the datasheet I see it has a impedance of 150 ohms (at 1Khz).
The loudspeaker is conected between Pin BO and ground through a condenser of 100k.
I supose is a problem of leveling impedances ¿ But How I do to sound the loudspeaker more strong ? |
Thank´s in advance |
