I am having a problem reading from an SD card. It seems to initialise OK, and doesn't return any errors when writing to the card (although as I can't read I havn't been able to confirm this).
The basic structure of the read code is as follows:
Command(CMD17,0,512,0xFF); // returns 0x00 (no error)
spi_read(0xFF); // returns 0x03 // what does this mean??
spi_read(0xFF); // returns 0xFF
...(forever more)
I have no idea why it is reading 0x03.. and never getting to 0xFE
Edit: 0x03 indicates an 'Internal Card Controler Error". I dont know why I am getting this error.
If anyone can shed any light on this problem it would be appreciated
Matt
mbro131
Posted: Fri Jun 02, 2006 1:57 am
Update: I still dont know what the error is, but i found that if I remove the write block I have prior to the read then the error is removed.. This suggests that my write block has some issues..
I'll post back if I find out for sure what this is.
