16F877 out of RAM/ROM => suggestions for new PIC??
weg22
PostPosted: Thu May 25, 2006 12:08 pm     Reply with quote
Hi all,
I'm pretty much maxed out in terms of RAM/ROM for my PIC16F877A (8K/368). I could just go to Microchip's web site and select a PIC with more memory, but I was hoping people could suggest a few to help narrow down my search. I have the PIC16F877A in 40-pin PDIP form and I want to use the same package (i.e. I'm hoping to get something that's interchangeable).
I noticed there's a PIC18F4680 with 32K/3328 which would be more than enough. Has anyone had any problems with this PIC?
Thanks!
treitmey
PostPosted: Thu May 25, 2006 12:47 pm     Reply with quote
Give us an idea what the scope of the project is.
LCD,Servo,Motor,DtoA,AtoD,wireless,USB,keypad,modem,..?
weg22
PostPosted: Thu May 25, 2006 1:13 pm     Reply with quote
Well, I will be controlling several servos as well as reading in data from a GPS unit (RS232) and Inertial Measurment Sensor (RS232). Also, I will need to use inverse trig functions such as atan2. I will be using interrupts such as:
INT_RDA: read in data from GPS device
INT_CCP: read the length of a PWM pulse (servo)
INT_TIMER0: generate PWM pulse
treitmey
good/bad chip...18F6622,18F6627,18F8527,18F8622
PostPosted: Thu May 25, 2006 1:50 pm     Reply with quote
I went to microchip and went to 18F4525 and down from there looking at
chips with 2-uart. anyone have a preference, run any of the following..
18F6622
18F6627
18F8527
18F8622
From here look at the pin out/prices/ect. AND MOST DEFINATLY the errata sheets. Some silicon have lots of errors.
weg22
PostPosted: Thu May 25, 2006 2:16 pm     Reply with quote
I don't think the ones you suggested are 40-pin PDIP. The 2nd UART is not a requirement. I will be pinging the IMU when I want data so I know when it will be coming in. I can wait for it...
I guess I will just go with the 18F4680 unless anyone has had trouble with this chip previously?
treitmey
PostPosted: Thu May 25, 2006 3:03 pm     Reply with quote
If 1 UART will do, I am very happy with the 18F4525. 40Pin dip with some motor controls.
For my 2 cents. I will allways use seperate hardware usarts for 2 serial streams, for anything short of debuging.
