Decompicating an array
hillcraft
PostPosted: Tue May 23, 2006 7:48 am     Reply with quote
A silly question I'm sure.
How can I decomplicate this line.
            if ((arr_usb_data_in[0]==0x03) &&
                (arr_usb_data_in[1]==0x72) &&
                (arr_usb_data_in[2]==0x65) &&
                (arr_usb_data_in[3]==0x73) &&
                (arr_usb_data_in[4]==0x65) &&
                (arr_usb_data_in[5]==0x74) &&
                (arr_usb_data_in[6]==0x00) &&
                (arr_usb_data_in[6]==0x00)) {   // .reset..
treitmey
PostPosted: Tue May 23, 2006 7:58 am     Reply with quote
Use memcmp with the passed in value of length.
hillcraft
PostPosted: Tue May 23, 2006 8:13 am     Reply with quote
What I can't figure out is how to stick the hex characters together to be used in the comparison . I cannot use the ascii equavalents becase of 03 etc
hillcraft
PostPosted: Tue May 23, 2006 8:21 am     Reply with quote
Can I do the following:
int8  arr_usb_data_compare[8]
 arr_usb_data_compare[0] = (0x03,0x72,0x65,0x65,0x65,0x74,0x00,0x00);
if (memcmp(arr_usb_data_compare,arr_usb_data_in,8)==0) {
or must it be the following
if (memcmp(arr_usb_data_compare[0],arr_usb_data_in[0],8)==0) {
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue May 23, 2006 8:36 am     Reply with quote
hillcraft wrote:
...or must it be the following
Don't do this, because it will probably produce an interesting artifact. The first members of your arrays will be treated as addresses and corresponding memory areas will be compared. Shocked
Try this instead (note the ampresands ):
if (memcmp(&arr_usb_data_compare[0], &arr_usb_data_in[0],8)==0) {
hillcraft
This doesn't seem to work!
PostPosted: Tue May 23, 2006 9:03 am     Reply with quote
The input data is definitely the same
           arr_usb_data_compare[0] = (0x03,0x72,0x65,0x73,0x65,0x74,0x00,0x00);
            if (memcmp(&arr_usb_data_in[0],&arr_usb_data_compare[0],8)==0) {
kender
Re: This doesn't seem to work!
PostPosted: Tue May 23, 2006 9:17 am     Reply with quote
It could be an error in the declaration of your constant array. Try:
int8 arr_usb_data_compare[8] = {0x03,0x72,0x65,0x73,0x65,0x74,0x00,0x00};
hillcraft
PostPosted: Tue May 23, 2006 9:27 am     Reply with quote
No it s not a constant array. I create a 8 element empty array that I then need to reuse throughout the program.
kender
PostPosted: Tue May 23, 2006 9:37 am     Reply with quote
Sorry, my mistake in the text, but the code (which doesn't have const) might still work.
PostPosted: Tue May 23, 2006 9:42 am     Reply with quote
int8 arr_usb_data_compare[8] = (0x03,0x72,0x65,0x73,0x65,0x74,0x00,0x00);
This creates an 8 element RAM array, and automatically initialises it with the values given.
This however wll not work:
However this:
strcpy(arr_usb_data_compare,"\x03Text2");
Will refill the whole array with the new values.
You can use hex, or octal values (\nnn, or \xnn), for anything that can't be directly typed as text.
hillcraft
I'm still stumped
PostPosted: Wed May 24, 2006 1:50 am     Reply with quote
This code:
int8 arr_usb_data_out_raw[8];
int8 arr_usb_data_out[8];
int8 arr_usb_data_in[8];
int8 arr_usb_data_compare[8];
strcpy(arr_usb_data_compare,"\x03\x72\x65\x73\x65\x74\x00\x00");
            for (i=0;i<8;i++)
              printf("%U: 0x%X\n\r",i,arr_usb_data_compare[i]);
Creates this result:
0: 0x03
1: 0x72
2: 0x65
3: 0x73
4: 0x65
5: 0x74
6: 0x00
7: 0x37
I cannot see where the 0x37 comes from
PostPosted: Wed May 24, 2006 2:34 am     Reply with quote
strcpy copies up-to-and-including the first zero. In your example code the second 0x00 at the end isn't copied resulting in arr_usb_data_compare[7] to contain just any random data that was already in memory.
When dealing with data containing possible null values, use memcpy instead of strcpy.
hillcraft
Sorted
PostPosted: Wed May 24, 2006 7:09 am     Reply with quote
Thanks, I live and learn...
