BASIC to C: What is the C equivalent of Mid$ in BASIC
FirstSteps
PostPosted: Tue May 23, 2006 12:03 pm     Reply with quote
I need to copy n bytes from anywhere in an array of int8 like the BASIC Mid$ statement. The binary bytes I'm working with may contain the null character. Can someone push me in the right direction? Thanks.
rwyoung
PostPosted: Tue May 23, 2006 12:23 pm     Reply with quote
strstr() and strcpy() and some pointer manipulation
Or write your own after checking the performance/size of the built in functions.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
PostPosted: Tue May 23, 2006 12:35 pm     Reply with quote
Use memcpy(). Here's an example that copies 6 bytes from the
middle of the source array to the start of the destination array.
The source data has a Null embedded in the middle of it.
String handling functions won't work with embedded nulls. You need
to use memory handling functions.
The program shown below has this output:
3 4 0 5 6 7
#include <16F877.H>
int8 source[10] = {1,2,3,4,0,5,6,7,8,9};
int8 dest[10];
int8 i;
memcpy(dest, &source[2], 6);
for(i = 0; i < 6; i++)
    printf("%u ", dest[i]);
PostPosted: Tue May 23, 2006 12:46 pm     Reply with quote
These are not going to work because...
Memcpy() is a possible solution. Let's say you have
MyString = "1234567890"
startPos = 3
charCount = 4
Print Mid$(MyString,startPos,charCount)      Prints "3456"
you can use
char MyString = "1234567890";
char Dest[10];
int startPos = 3 - 1;       // minus 1 because C starts counting at 0
int charCount = 4;
memcpy(&MyString[startPos], Dest, charCount);
Dest[4] = '\0'; Add string terminator
printf("%s", Dest);
FirstSteps
PostPosted: Tue May 23, 2006 1:11 pm     Reply with quote
Thanks to all. [bow from waist]
PostPosted: Tue May 23, 2006 1:37 pm     Reply with quote
Beaten by PCM... Now I had a double post.
I should learn to type faster. Sad
