software PWM,
greenears
software PWM,
PostPosted: Mon May 22, 2006 1:44 pm     Reply with quote
HI
I'm pretty new to PIC programming and I'm trying to program software pwm (see code)
//interrupt routines
unsigned int16 pwm_duty_cycle;
unsigned int1 bit_state=0;
#int_timer3 //
void timer3_isr() {
   switch(bit_state) {
   case 1:
      OUTPUT_FLOAT(PIN_BIRD1B);
      bit_state=0;
      set_timer3(0xFFFF-pwm_duty_cycle);   // pwm_duty_cycle
   case 0:
      OUTPUT_LOW(PIN_BIRD1B);
      bit_state=1;
      set_timer3(0xFFFF-(50-pwm_duty_cycle));   // period-pwm_duty_cycle
// Initialization
void init()
   // Setup oscillator mode @ 32MHz
//   setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_31250|OSC_PLL_ON);
   #asm
   MOVLW  0b01110000   // setup internal oscillator
   MOVWF  0xFD3
   MOVLW  0b11000000 // enable PLL
   MOVWF  0xF9B
   #endasm
   // Setup peripherals
   setup_adc_ports(AN0_TO_AN4);
   setup_adc(ADC_CLOCK_DIV_32);         // ADC clock must be set such to ensure TAD=1.6us minimum (TOSC = 0.05us @ 20MHz)
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32); //
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);   /
   setup_timer_2(T2_DIV_BY_16,255,1);
   setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
   setup_ccp1(CCP_PWM);
   setup_ccp2(CCP_PWM);
   //setup_comparator(NC_NC_NC_NC);
   //setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   // Setup PIC I/O ports; 1 indicates the pin is input and 0 output.
   set_tris_a(0b00011110);
  set_tris_b(0b11110011);
   set_tris_c(0b10000000);
   set_tris_d(0b11111111);
   set_tris_e(0b100);
   // Setup interrupts.
   enable_interrupts(INT_TIMER1);   // Anemometer monitoring
   enable_interrupts(INT_TIMER3);   // BIRDS PWM
   enable_interrupts(global);
// MAIN routine
   init();
   //while (true) {
led_on_led0();
   pwm_duty_cycle=20; // trying to set the duty cycle to control actuators
led_off_led0();
It is a PIC18F4620 @32MHz, TImer3 is 16bit
so after my calculation
it overflows every 65.5ms
(4/32E6 * 65535 *8=65.5ms)
and if I want a frequency of 20kHz (50us period) of my PWM
.....(4/32E6 * x *8=50us) => x=50 counts in timer3
my problem is that I can not change the fraction of high to low states of the pwm...
Are my calculations correct? Is it very unelegant to do PWM this way/are there mistakes?
Did I enable the Interrupts correctly...?
I'm stuck on this topic for quite a while now...
Thank you very much!
(Youre saving my life)
best
mirko
Rolling Eyes
PostPosted: Mon May 22, 2006 1:57 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=20050
