Buck Boost reg?
Buck Boost reg?
PostPosted: Tue May 23, 2006 5:34 pm     Reply with quote
My first real poject using PIC and CCS, I'm looking to create a battery powered GSM project using a SAFT 3.9v 16amp battery, looking for some advice on a low external component count buck / boost reg capable of keeping the 3.9v output as long as possible
Am I right looking at buck / boost or is there a better way
Thx in advance
P.S. Need shutdown pin.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue May 23, 2006 6:03 pm     Reply with quote
Guest wrote:
...using a SAFT 3.9v 16amp battery, looking for some advice on a low external component count buck / boost reg capable of keeping the 3.9v output as long as possible
Am I right looking at buck / boost or is there a better way?
If your max battery voltage is +3.9V and the output should stay at +3.9V, you need a pure boost.
SherpaDoug
PostPosted: Wed May 24, 2006 4:50 am     Reply with quote
Pure buck or pure boost is easier. The worst case is to have your battery voltage vary through your output voltage. Avoid it if possible.
