Problem with 74595 Code
deltatech
PostPosted: Sat May 20, 2006 3:51 pm     Reply with quote
Hi I am trying to run EX_EXPIO.C on a CCS Software Board .
I have 2 Questions In the intro of the example it says "when button 1 is pushed, LED 1 will toggle green. Button 2 will toggle LED 2. "
But In the code of 74595 These butons are not defined or mapped to any ports or am I Missing some thing here ? .
The Other is when I run this exapmple with ICD-U40 I get an error mesage "Could not run Programme The TByteStack was empty "
can any one tell me what i am doing wrong
Any Help will be appriciated.
Thanks in advance
EX_EXPIO.C
////                         EX_EXPIO.C                              ////
////     This program shows how to use the 74165.C and 74595.C       ////
////  libraries for extended input and output.                       ////
////     When button 1 is pushed, LED 1 will toggle green.  Button   ////
////  2 will toggle LED 2.  However, when both buttons are pushed,   ////
////  LED 3 will toggle green.                                       ////
////  Configure the CCS prototype card as follows:                   ////
////               74165 pin    Protoboard                           ////
////                  11           Button 1                          ////
////                  12           Button 2                          ////
////                  13           gnd                               ////
////                  14           gnd                               ////
////                  15           gnd                               ////
////                  3            gnd                               ////
////                  4            gnd                               ////
////                  5            gnd                               ////
////                  6            gnd                               ////
////                  8            gnd                               ////
////                  16           +5V                               ////
////                  9            pin B5                            ////
////                  1            pin B3                            ////
////                  2            pin B4                            ////
////               74595 pin    Protoboard                           ////
////                  15           LED 1                             ////
////                  1            LED 2                             ////
////                  2            LED 3                             ////
////                  3            gnd                               ////
////                  4            gnd                               ////
////                  5            gnd                               ////
////                  6            gnd                               ////
////                  7            gnd                               ////
////                  8            gnd                               ////
////                  13           gnd                               ////
////                  16           +5V                               ////
////                  10           +5V                               ////
////                  14           pin B2                            ////
////                  11           pin B1                            ////
////                  12           pin B0                            ////
#include <16F877.h>
#include <74595.c>
#include <74165.c>
[b]void main() {
   BYTE data;
   do {
      read_expanded_inputs (&data);
      data |= 0xF8;                           //Force the unused input bits on
      data -= (!(data&0x01)&!(data&0x02))<<2; //Turn on bit 2 it both inputs are
                                              //toggled
      write_expanded_outputs (&data);
   } while (TRUE);
}[/b]
74595.C
////   Library for a 74165 Expanded Input Chip                         ////
////   Any number of these chips may be connected in series to get     ////
////   8 additional inputs per chip.  The cost is 3 I/O pins for       ////
////   any number of chips.                                            ////
////    read_expanded_inputs(ei);  Reads the array ei from the chips   ////
[b]#IFNDEF EXP_IN_ENABLE
#define EXP_IN_ENABLE   PIN_B3
#define EXP_IN_CLOCK    PIN_B4
#define EXP_IN_DI       PIN_B5
#define NUMBER_OF_74165 1
#ENDIF
void read_expanded_inputs(BYTE *ei) {
  BYTE i;
  output_high(EXP_IN_CLOCK);
  output_low(EXP_IN_ENABLE);      // Latch all inputs
  output_high(EXP_IN_ENABLE);
  for(i=1;i<=NUMBER_OF_74165*8;++i) {      // Clock in bits to the ei structure
    shift_left(ei,NUMBER_OF_74165,input(EXP_IN_DI));
    output_low(EXP_IN_CLOCK);
}[/b]
Humberto
PostPosted: Sat May 20, 2006 9:14 pm     Reply with quote
The buttons and Leds are not defined nor mapped because they are not connected to any pin of the PIC.
The buttons are connected to the inputs A (pin 11) and B (pin 12) of the 74165.
The Leds are connected to the outputs 0 ( pin 15), 1 (pin 1), 2 (pin 2) of the 74595.
PD: It is not allowed to post CCS code without its explicit consent.
Humberto
deltatech
PostPosted: Sun May 21, 2006 7:50 am     Reply with quote
Thanks Humberto I am sorry i didnt know You couldnt Post CCS Code OOPs Surprised
PostPosted: Sun May 21, 2006 8:33 am     Reply with quote
Actually though, worth pointing out that this particular example, is one of the few that _doesn't_ say this.
Most have a very careful copywrite message to this effect.
dyeatman
PostPosted: Sun May 21, 2006 8:41 am     Reply with quote
Mine all have the copyright notice so maybe it was edited out before posting?
Humberto
PostPosted: Sun May 21, 2006 8:52 am     Reply with quote
Ttelmah wrote:
Not exactly. All this drivers in all the different versions that I have, keep the CCS copyright warning.
Humberto
PostPosted: Sun May 21, 2006 9:59 am     Reply with quote
The funny thing is that I have a version for this one that doesn't. I looked, just 'out of interest', and unlike the rest of the CCS files, this one lacked their normal header. That was why I commented.
It was one they sent seperately, rather than the normal included versions.
