Need to create new int to service PIR3 on 18F6680...HOW?
ChrisL
PostPosted: Tue Sep 18, 2007 7:10 pm     Reply with quote
Hi All,
Working to finish the CAN J1939 conversion using interrupts. It does not appear (or I missed it) that there is an int to service PIR3 in the list of INTs for the PIC18F6680. Setting the bit in INTCON for PEIE is simple, but how do you code a service routine to manage that spicific interrupt...?
It would be great if anybody knows how CCS calculates the addresses that are in the device table. I would like to include it as a standard entry in the device table along with all the other INTs if possible.
Thank you,
Chris
PostPosted: Tue Sep 18, 2007 7:47 pm     Reply with quote
Version 4.056 of the compiler has the following values. I think these
are the ones you want.
#define INT_CANIRX                0xA380
#define INT_CANWAKE               0xA340
#define INT_CANERR                0xA320
#define INT_CANTX2                0xA310
#define INT_CANTX1                0xA308
#define INT_CANTX0                0xA304
#define INT_CANRX1                0xA302
#define INT_CANRX0                0xA301
ChrisL
PostPosted: Wed Sep 19, 2007 1:39 am     Reply with quote
PCM Programmer,
Here is the function we are trying to replace from PIC 18C Compiler;
#pragma code InterruptVectorLow = 0x0018
void InterruptVectorLow( void )
  _asm
    goto InterruptHandlerLow
  _endasm
// Low priority interrupt routine
#pragma code
#pragma interruptlow InterruptHandlerLow
void InterruptHandlerLow( void )
   if (PIR3 != 0x00)
      J1939_ISR();
I don't seem to be able to get any of the items in the list you provided to work..????
Thank you,
Chris
PostPosted: Wed Sep 19, 2007 2:58 am     Reply with quote
  _asm
  _endasm
#pragma code
   if (PIR3 != 0x00)
      J1939_ISR();
CCS has a more advanced mechanism for creating interrupt handlers than the C18 compiler provides. The CCS compiler creates the interrupt dispatcher for you, saves all registers and clears the interrupt flag when you are finished. All you have to do is write the interrupt functions preceded by a #int_xxx keyword, where xxx is the name of the interrupt you want to handle.
I had a quick look at the C18 code from AN930 and it looks like for porting the code to CCS it is best to forget about the CCS way of handling interrupts. Very nice but the code is not written in a way that allows for an easy port. Luckily CCS provides a method for you to write your own dispatcher which is exactly what the C18 code does.
Replace the complete code fragment from above by:
#int_global
   if (PIR3 != 0x00)
      J1939_ISR();
Note that the InterruptVectorLow() function call is missing, the CCS compiler generates this for you implicitly.
ChrisL
PostPosted: Wed Sep 19, 2007 9:48 am     Reply with quote
ckielstra,
Thank you again for your help.
Do you know the method CCS uses to arrive at the addresses for the INTs that they create in the device profile that they publish. I would love to know the trick so that in the futrure we could create our own...!
Thank you,
Chris
ChrisL
PostPosted: Wed Sep 19, 2007 10:14 am     Reply with quote
ckielstra,
Your code fragment:
#int_global
   if (PIR3 != 0x00)
      J1939_ISR();
results in
Unprotected call in a #INT_GLOBAL
Any suggestions..?
Thank you,
Chris
dilandau
PostPosted: Wed Sep 21, 2011 5:09 am     Reply with quote
For author:
Maybe this link will help:
http://www.ccsinfo.com/forum/viewtopic.php?t=27060
For previous answer:
Have you tried using
#int_default
