:shock:
LEVENT
:shock:
PostPosted: Wed May 17, 2006 2:21 am     Reply with quote
hi everbody..
I want to control a motor.In my project,I could write a program like that :
   int num1, num2, num3;
   static byte value;
   long move;
   int16 cm;
   char yon;
   setup_adc_ports(AN0_AN1_AN3);
   set_adc_channel(0);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1, 999, 1);
   output_low(pin_d1);
 printf("DISTANCE(cm) : \n\r" );
  num1 = getch()&0x0F;
  delay_ms(1);
  num2 = getch()&0x0F;
  delay_ms(1);
  num3 = getch()&0x0F;
  printf("INIT...\n\r");
  cm = (num1*100) + (num2*10) + num3;
  move = (long)cm*4;
  printf("move = \n\r",move);
  printf(" 0- BACKWARD \n\r");
  printf(" 1- FORWARD  \n\r");
  yon = getch();
  motor_sur(value, move, yon);
motor_sur(byte value, long move, char yon)
long count;
   switch(yon)
      case '0':              //----motor forward------
       output_low(pin_d0);
      case '1':             //-----motor backward-------
       output_high(pin_d0);
setup_ccp1(ccp_pwm);
value = read_adc();
set_pwm1_duty(value);
       while(count <= move)   //move motor
   if(input(pin_a4));               // if pulse change low to high
    count =count + 1;
        while(input(pin_a4));    // while pulse is high
           delay_us(1);
          while(!input(pin_a4)); //while pulse is low
           delay_us(1);
           value = read_adc();
setup_ccp1(ccp_off);
As you see,The motor's distance controlled by user which distance (in cm) can send by RS232 (for exmp. 200cm)...And I read pulses from motor and control the motor's running time. This program is not run perfectly...Because the move value is not correct and I can't write this number on the pc screen with printf() function.I can't accept 3digit number at one times.Can anybody help me for this problems??
PostPosted: Wed May 17, 2006 10:12 am     Reply with quote
static byte value;
long move;
int16 cm;
char yon;
It looks like you're trying to experiment with CCS data types by using
one of each different type. You shouldn't do that, because it makes the
program confusing to read. In CCS, the data types of "byte", "int", "int8"
and "char" are all the same. They are all 8-bit unsigned integers. Get
rid of all the different declarations for 8-bit values and just use one of
them. I suggest using "int8". Also, "int16" is the same as "long". Both
are unsigned 16-bit integers.
In the code above, all of your "num" values are only 8 bits, but
the first two intermediate results are 16-bit values. So your code
will cause the MSB of each intermediate result to be discarded.
You can fix this by declaring the "num" variables as int16, or you
can cast them to 16-bit values in the equation. Example:
cm =  ((int16)num1*100) + ((int16)num2*10) + (int16)num3;
PostPosted: Wed May 17, 2006 10:18 am     Reply with quote
As a seperate 'comment', perhaps also post with a title that reflects your problem. I hadn't looked at this post thinking 'junk', and I suspect quite a few of the other peple who post replies have done the same. It was only when I saw that a reply had been posted by one of the respected posters here (PCM programmer), that I bothered to look...
