4x20 LCD
dincerk
4x20 LCD
PostPosted: Sun May 14, 2006 10:07 am     Reply with quote
when i want to use 4x20 lcd, i saw that the connection of it is just like below.
B0 enable
B1 rs
B2 rw
B4 D4
B5 D5
B6 D6
B7 D7
how can i change it to
D0 enable
D1 rs
D2 rw
D4 D4
D5 D5
D6 D6
D7 D7
carmarmu
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sun May 14, 2006 10:38 am     Reply with quote
You only must change in the LCD4x20.C libray the pins assigning them to the new pins that your you want.
If you open the librery you will see that it takes a head where explains everything.
Luck!
**CaRmArMu** Valencia (Spain)
carmarmu
PostPosted: Sun May 14, 2006 10:40 am     Reply with quote
Libray or librery not... library Smile
A failed to my fingers and always in the same word Smile
Luck!
