changing an array in the main
cjusto
PostPosted: Sat May 13, 2006 10:16 am     Reply with quote
hi everybody!
i have a doubt.
when i declare an array like this (global variable):
BYTE in_buffer[10] = {0,0,0,0,0,0,0,0,0,0};
and i make some code after this.
in a certain point in the main function i need to rewrite the values. how to make it?
i tried this but doesn't work:
in_buffer[] = {3,45,48,48,49};
and if something like this is possible, can i just write some of the values, like the first 5 of the array???
thanks!
Mark
PostPosted: Sat May 13, 2006 10:46 am     Reply with quote
Try this:
in_buffer[0] = 3;
in_buffer[1] = 45;
in_buffer[2] = 48;
in_buffer[3] = 48;
in_buffer[4] = 49;
There are other ways of doing this but a lot depends on what you are actually trying to accomplish.
cjusto
PostPosted: Sat May 13, 2006 11:08 am     Reply with quote
hi mark.
i didn't say that. but i want something else.
what u are telling me i know i can do.
i forgot to say that i already did that.
thanks anyway.
i really want sometthing to change the array in one line.
PostPosted: Sat May 13, 2006 11:54 am     Reply with quote
Then just write a macro to do it. Example:
#include <16F877.H>
int8 in_buffer[80];
#define load_buffer(x0, x1, x2, x3, x4)  \
in_buffer[0] = x0; \
in_buffer[1] = x1; \
in_buffer[2] = x2; \
in_buffer[3] = x3; \
in_buffer[4] = x4;
load_buffer(3,45,48,48,49);
carmarmu
View user's profile Send private message Send e-mail MSN Messenger
Re: changing an array in the main
PostPosted: Sat May 13, 2006 12:44 pm     Reply with quote
When you declare an array, and you don´t put the dimension into brackets, the compiler automatically assigns the dimension of the components that you put after the symbol “=”.
In order to change the value of each one of the elements, you will have to write as it is the position of the element that you want to change.
Remember that element “1” of the Array is the “0” for the compiler. Therefore, if sights your program, you have several failures.
For example....
If you first write in_buffer[10] = {0,0,0,0,0,0,0,0,0,0} it´s wrong to write later in_buffer[] = {3,45,48,48,49} because dimensions don´t be equal.
If you want to change only some values, use:
in_buffer[Z] = data; where Z is the position, and data, the data you want assign.
Regards.
cjusto wrote:
hi everybody!
i have a doubt.
thanks!
**CaRmArMu** Valencia (Spain)
cjusto
PostPosted: Sat May 13, 2006 1:12 pm     Reply with quote
hi!!!
thanks for the answers.
i think this will work fine.
in_buffer[4] = x4;
thanks!!
