PIC12F629 & ENABLE_INTERRUPTS()
markleman
PostPosted: Thu Mar 30, 2006 10:15 am     Reply with quote
Today I was examining a .lst produced by the compiler and was puzzled so I made the minimum example:
#include<C:\Program Files\PICC\Devices\12F629.h>
#FUSES NOWDT,PUT,NOPROTECT,BROWNOUT,INTRC_IO,NOMCLR
  ENABLE_INTERRUPTS(INT_RA0|INT_RA1|INT_RA3|INT_RA4|INT_RA5)
produced (with my comments added after ;'s) :
CCS PCM C Compiler, Version 3.249, 30611               30-Mar-06 16:38
....snip....
..........ENABLE_INTERRUPTS(INT_RA0|INT_RA1|INT_RA3|INT_RA4|INT_RA5);
000F:  BSF    03.6   ; Set bit RP1 in status - reserved on 12F629!
0010:  BSF    0B.3   ; set GPIE in INTCON - ok
0011:  MOVLW  3B     ; mask for RA bits - ok,3B is the right mask
0012:  BSF    03.5   ; Set bit RP0 in status - ok back switch to bank1
0013:  BCF    03.6   ; Clear bit RP1 in status - reserved on 12F629!
0014:  IORWF  16,F   ; OR mask in W with IOC and keep in IOC
....snip....
What are the instructions at 000F and 0013 doing setting and clearing RP1 on a 12F629? The microchip data sheet says 'This bit is reserved and should be maintained as ‘0’'
No where else in my code (the real code not this little example Confused) does 03.6 or 03.7 get used only 03.5
Regards, Mark Leman
PostPosted: Thu Mar 30, 2006 12:50 pm     Reply with quote
You may have found a long-term bug. I checked PCM vs. 3.191 and
it does the same thing.
markleman
PostPosted: Thu Mar 30, 2006 3:08 pm     Reply with quote
Question is : is it actually going to stop the code working?
So far I think not but I can't rely on that being the case so I think for the moment a little inline assembler might have to go in Sad
markleman
PostPosted: Thu May 11, 2006 7:34 am     Reply with quote
This problem has been comfirmed by CCS and they say
"This problem is fixed in our version 4 release. We are late getting it out.
Sorry for the delay."
