teraterm
htp
teraterm
PostPosted: Thu May 11, 2006 12:48 pm     Reply with quote
I am using Teraterm. I want to send a file to PIC on RS232. My definition is as follow:
#include <16F877A.h>
I use send file from file menu, but it is not done successfully. Does anyone have any idea? Shall I set any configuration?
Regards
PostPosted: Thu May 11, 2006 4:38 pm     Reply with quote
You didn't show us the rest of your program, which hopefully is short.
What do you do with the bytes after you receive them ? The 16F877A
has only a few hundred bytes of RAM available. The file must be
small enough to fit in the limited amount of RAM.
My guess is that your PIC program is probably not getting the characters
from the UART quickly enough and it's getting an overrun error and is
locking up. To clear the "lock up" condition automatically, add the
ERRORS directive as shown below. You'll still lose characters, but at
least it won't lock up.
Then work on fixing your code so that it reads all characters from the
UART quickly. See the CCS example file, EX_SISR.C for an example
of a interrupt-driven receive buffer.
Gege
PostPosted: Fri May 12, 2006 2:19 am     Reply with quote
Did you try by checking the "Binary Option" into Teraterm (into the file dialogue box)
jma_1
PostPosted: Fri May 12, 2006 6:30 am     Reply with quote
Are you processing each group or packet of data sent? If yes, you might want to consider including a transmit delay before sending the next packet. Try starting small, sending only a few bytes and check if they are received correctly. Perhaps the PIC code is not interpretting the bytes as intended.
Cheers,
JMA
carmarmu
View user's profile Send private message Send e-mail MSN Messenger
Re: teraterm
PostPosted: Fri May 12, 2006 12:28 pm     Reply with quote
Please, shows the rest of program, where beams the shipment.
I you want i correct you.
Regards!!!
htp wrote:
Regards
**CaRmArMu** Valencia (Spain)
