i2c-com freezes
davey
i2c-com freezes
PostPosted: Wed May 10, 2006 10:49 am     Reply with quote
Hi!
Below you can see the source-code for a i2c-test-program. I´m sending two bytes of data from one master to a slave. My problem is that I don´t get an acknowledge for the first data-byte that I´m sending....also, after a while the communication freezes and the SLAVE-pic stops working.
Does anyone have an idea where the problem is located?
MASTER-CODE
#include <i2c_test.H>
#fuses NOWDT
#use i2c(master,sda=PIN_C4,scl=PIN_C3,FORCE_HW)
void send_to_slave() //I2C-funktion
      port_d ^= 1;
      i2c_start();
      if(!i2c_write(0x6C)) //address to slave
         delay_us(20);
         if(!i2c_write(0x51))    //data1
            delay_us(20);
            i2c_write(0x1B);    //data2
      i2c_stop();
main()
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   setup_port_a(NO_ANALOGS);
   setup_psp(PSP_DISABLED);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   set_tris_d(0x00);
   set_tris_c(0x00);
   while(1) //test-loop
      send_to_slave();
SLAVE-CODE
#fuses NOWDT
#use i2c(slave,sda=PIN_C4,scl=PIN_C3,address=0x6C,force_hw)
int16 temp;
byte received;
typedef enum {FIRST_READ, LAST_READ} I2C_STATE;
I2C_STATE i2c_status=FIRST_READ;
#int_ssp
receive_isr()
   port_d ^= 1; //indicator (reaching ISR?)
   if(i2c_poll())
      if(!bit_test(i2c_stat,5)) //check to see if last byte was an address
         //take care of the address-byte
         received=i2c_read();
      else if(i2c_status==FIRST_READ && bit_test(i2c_stat,5))
         //first data-byte
         temp=received;
         i2c_status=LAST_READ;
      else if(i2c_status==LAST_READ && bit_test(i2c_stat,5))
         //second data-byte
         temp=(temp<<8)&0xFF00;
         temp=temp+received;
   bit_clear(i2c_ctrl,3);
main()
   set_tris_d(0x00);  // PORT-D: all output
   set_tris_c(0xFF);  // PORT-C: all input
   enable_interrupts(INT_SSP);
   while(1){}
