i2c problem: slave freezes i2c bus
cjusto
PostPosted: Wed May 10, 2006 2:48 pm     Reply with quote
hi guys!
i am trying to make an i2c based protocol message.
i need to interact 2 pics (16F877).
i am sending 6 bytes from master to slave. till here no problem.
after recognizing the correct sequence i send data from slave to master.
i can send one byte with no problems.
when i send the second, the clock line remains low. when i disconnect the line in the slave's side, it becomes in a high level.
can someone check what i am doing wrong??
here is the code for master:
#include <16F877A.h>
#use delay (clock=4000000)
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#use i2c (MASTER, SDA=PIN_C4, SCL=PIN_C3)
#define SLAVE_ADDRESS 0xA0
void initI2C()
   output_float(PIN_C3);
   output_float(PIN_C4);
void main ()
   int i;
   BYTE in_buffer[11] = {0,0,0,0,0,0,0,0,0,0};
   initI2C();
   printf("MASTER \r\n");
while(TRUE){
   i2c_start();
   printf("i2c start\r\n");
   i2c_write(SLAVE_ADDRESS);  // Device Address
   printf("address sent \r\n");
   i2c_write(0x01);
   printf("SOH sent\r\n");
   i2c_write(0x30);
   printf("0 sent\r\n");
   i2c_write(0x30);
   i2c_write(0x31);
   printf("1 sent \r\n");
   i2c_write(0x32);
   printf("2 sent\r\n");
   i2c_write(0x17);
   printf("etb sent \r\n");
//begining slave's data reception
//inicio de recepcao de dados do slave
   i2c_start();
   i2c_write(SLAVE_ADDRESS + 1);
   printf("enviei endereco + 1 \r\n");
   for(i=0;i<2;i++)
   //   delay_ms(100);
      in_buffer[i] = i2c_read(0xff);
      printf("in_buffer[%d] = %c \r\n",i, in_buffer[i]);
   i2c_stop();
   printf("i2c stop\r\n");
               delay_ms(3000);
here is the code for the slave:
#define SLAVE_ADDRESS 0xa0
#use i2c (SLAVE, SDA=PIN_C4, SCL=PIN_C3, address= SLAVE_ADDRESS, FORCE_HW)
int x = 0;
int y = 0;
int code_full = 0;
int code_done = 0;
BYTE in_buffer[10] = {0,0,0,0,0,0,0,0,0,0};
//BYTE out_buffer[11] = {0,0,0,0,0,0,0,0,0,0,0};
BYTE out_buffer[2] = {0,0};
void initI2C()
#INT_SSP
void ssp_interupt ()
   if(i2c_poll())
       in_buffer[x] = i2c_read(0xff);
      printf("\r\nrecebi %d",in_buffer[x]);
      x++;
   else //if(code_done)
      i2c_write(out_buffer[y]);
      printf("enviei %d\r\n",out_buffer[y]);
      y++;
   if(x==7)
      x = 0;
      code_full = 1;
   if(y==11)
      y = 0;
      code_done = 0;
//clear_interrupt(INT_SSP);
void main ()
   int incoming;
   int i;
   enable_interrupts(INT_SSP);
   printf("\r\nSLAVE: main ");
   if(code_full)
      if(in_buffer [1] == 1)                 //soh
         if(in_buffer [2] == 48)             //0
            if(in_buffer [3] == 48)          //0
               if(in_buffer [4] == 49)       //1
                  if(in_buffer [5] == 50)    //2
                     if(in_buffer [6] == 23) //etb
                  out_buffer[0] = 2;   //stx
   printf("\r\n buffer0 written");
                out_buffer[1] = 48;  //0
   printf("\r\n buffer1 written");
                        code_done = 1;
                        printf("escrevi valores\r\n");
   code_full = 0;
i hope someone can help me!!
thank you
