correct inizialization of i2c bus
Fabri
PostPosted: Tue May 09, 2006 10:16 am     Reply with quote
Hi Everibody,
Sometimes, after power-up, the i2c bus doesn,t work and I have to restart the equipment.
I have a doubt about:
Does #use i2c() inizialize direction register, port level and stop status or must I do that manually ?
Any suggestion about ?
Thanks for support,
PostPosted: Tue May 09, 2006 12:01 pm     Reply with quote
The library code does setup the TRIS, and it sets up the i2c registers
if you're using hardware i2c.
