PIC 16F627 at 37KHZ
elpic
PIC 16F627 at 37KHZ
PostPosted: Tue May 09, 2006 7:19 am     Reply with quote
Hi, im working with PIC16F627 , INTRC_IO 4Mhz. I need to set oscillator at 37KHZ, Can I do this?
Waiting for answer, thank you.
Best wishes
treitmey
PostPosted: Tue May 09, 2006 7:48 am     Reply with quote
Faster is normally better. Why do you want to set the clock to 37KHz?
Are you trying to use the Dual speed feature?
PCON REGISTER (ADDRESS: 8Eh)
bit 3 OSCF
jim
yes
PostPosted: Tue May 09, 2006 9:11 am     Reply with quote
If they data sheet says you can set up the internal clock to that speed, you should be able to use the setup_oscillator() command
