jleblanc
For loop compiler bug |
Posted: Wed May 17, 2006 1:17 pm |
I'm having a problem with a particular for loop in one of my programs and I think it is a problem with the compiler. The for loop is supposed to count backwards from 4 to 0; however what ends up happening is the program gets stuck in an infinite loop with the integer variable counting down, overflowing, then counting down again, etc.
I've included source code that demonstrates this problem. I have not tried it on another PIC. I have also included the assembly generated when I compile this program. If someone could try this code and confirm or deny my results that would be much appreciated.
Code: | #include <18F4620.h>
#device ICD=TRUE
#device adc=8
#fuses HS,WDT8,NOPROTECT,IESO,NOPUT,NOCPD,STVREN,NOLVP,NOWRT,NOWRTD,NOEBTR
#fuses NOCPB,NOEBTRB,NOWRTC,NOWRTB,MCLR
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=COM1,ERRORS,restart_wdt)
#include <stdio.h>
int x=0;
for (x=4; x>=0; x--)
printf("x = %d\r\n",x);
printf("\r\nDone\r\n");
Code: | .................... void main()
013A: CLRF FF8
013C: BCF FD0.7
013E: CLRF FEA
0140: CLRF FE9
0142: BSF FB8.3
0144: MOVLW 56
0146: MOVWF FAF
0148: MOVLW 00
014A: MOVWF FB0
014C: MOVLW 26
014E: MOVWF FAC
0150: MOVLW 90
0152: MOVWF FAB
0154: MOVF FC1,W
0156: ANDLW C0
0158: IORLW 0F
015A: MOVWF FC1
015C: MOVLW 07
015E: MOVWF FB4
0160: CLRF 05
0162: CLRF 06
0164: CLRF 07
.................... int x=0;
0166: CLRF 08
.................... for (x=4; x>=0; x--)
0168: MOVLW 04
016A: MOVWF 08
.................... printf("x = %d\r\n",x);
016C: CLRF 09
016E: MOVF 09,W
0170: RCALL 0004
0172: INCF 09,F
0174: MOVWF 00
0176: CLRWDT
0178: BTFSS F9E.4
017A: BRA 0176
017C: MOVWF FAD
017E: MOVLW 04
0180: SUBWF 09,W
0182: BNZ 016E
0184: MOVFF 08,0A
0188: MOVLW 1F
018A: MOVWF 0B
018C: BRA 0060
018E: MOVLW 0D
0190: CLRWDT
0192: BTFSS F9E.4
0194: BRA 0190
0196: MOVWF FAD
0198: MOVLW 0A
019A: CLRWDT
019C: BTFSS F9E.4
019E: BRA 019A
01A0: MOVWF FAD
01A2: DECF 08,F
01A4: BRA 016C
.................... printf("\r\nDone\r\n");
01A6: CLRF 09
01A8: MOVF 09,W
01AA: RCALL 001E
01AC: IORLW 00
01AE: BZ 01BC
01B0: INCF 09,F
01B2: CLRWDT
01B4: BTFSS F9E.4
01B6: BRA 01B2
01B8: MOVWF FAD
01BA: BRA 01A8
01BC: BRA 01BC |
newguy
Posted: Wed May 17, 2006 1:26 pm |
Hate to rain on your parade, but your for loop is doing exactly what you're asking it to.
You declare x as an unsigned integer. In the loop you set x = 4, and decrement x on every pass through the loop. Your test for the continuation of the loop is to test if x is greater than or equal to 0.
Let's say that on a particular pass through the loop, x = 0. Since 0 is equal to 0, the loop executes. Once it executes, x is decremented and becomes 255. 255 is indeed greater than 0, so the loop continues.
Change your definition of x to:
It will perform as you expect with this change. |
jleblanc
Posted: Wed May 17, 2006 1:27 pm |
Addendum:
I noticed what was wrong. I needed to add the "signed" keyword infront of x's declaration. However what I find puzzling is how without this keyword the application would count negative numbers when it ran (which if "int" is unsigned by default it shouldn't do).
It was only when I tried setting x equal to negative 2 to do a test of the ">=" operator and the compiler flaged that as not in the valid range for that variable that I caught this.
So it appears a variable declared only as "int" exhibits properties of both the signed and unsigned types.
Edit: Wait, I just realized that was probably the printf() call interpretting the numbers as signed because of the %d.
Nevermind; nothing to see here. Move along. |
