KeyPad Problem
deltatech
KeyPad Problem
PostPosted: Fri May 05, 2006 2:04 pm     Reply with quote
Hi All I got this key pad example off the forumhttp://www.ccsinfo.com/forum/viewtopic.php?t=26333.
I have tried to make it work but its not working , I know the keys are working because when i press a key one of the segmonts on the lcd comes on .
I also dont understand what is the function of kbd_init(); it is empty but in the instructions it says to call it before every function ?
Thanks for your help
include "G:\Program Files\PICC\Project\keypad2.h"
//This is a modification of CCS keypad driver (KBDD.c) with flexible pins connections.
//Code:
////                             Flex_KBD.C                            ////
////                  Generic keypad scan driver                       ////
////  kbd_init()   Must be called before any other function.           ////
////  c = kbd_getc(c)  Will return a key value if pressed or /0 if not ////
////                   This function should be called frequently so as ////
////                   not to miss a key press.                        ////
//Keypad connection:
#define col0 PIN_B0
#define col1 PIN_B1
#define col2 PIN_B2
#define row0 PIN_B3
#define row1 PIN_B4
#define row2 PIN_B5
#define row3 PIN_B6
char kbd_getc( );
void kbd_init();
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
                         {'4','5','6'},
                         {'7','8','9'},
                         {'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33    // Set this number to apx n/333 where
                                  // n is the number of times you expect
                                  // to call kbd_getc each second
{char key;
   port_b_pullups(TRUE);
kbd_init();
key=kbd_getc();
printf(key);
void kbd_init() {
short int ALL_ROWS (void)
   if (input (row0) & input (row1) & input (row2) & input (row3))
      return (0);
      return (1);
char kbd_getc( ) {
   static byte kbd_call_count;
   static short int kbd_down;
   static char last_key;
   static byte col;
   byte kchar;
   byte row;
   kchar='\0';
   if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
       switch (col) {
         case 0   : output_low(col0);
               output_high(col1);
               output_high(col2);
         case 1   : output_high(col0);
               output_low(col1);
               output_high(col2);
         case 2   : output_high(col0);
               output_high(col1);
               output_low(col2);
       if(kbd_down) {
         if(!ALL_ROWS()) {
           kbd_down=false;
           kchar=last_key;
           last_key='\0';
       } else {
          if(ALL_ROWS()) {
             if(!input (row0))
               row=0;
             else if(!input (row1))
               row=1;
             else if(!input (row2))
               row=2;
             else if(!input (row3))
               row=3;
             last_key =KEYS[row][col];
             kbd_down = true;
          } else {
             ++col;
             if(col==3)
               col=0;
      kbd_call_count=0;
  return(kchar);
treitmey
PostPosted: Fri May 05, 2006 2:48 pm     Reply with quote
If its empty you don't need to call it. This is a cut/paste/edit/comment
problem where a comment was left from an older version of the driver.
I think that would normally be used to set the TRIS pin direction.
But TRIS is not needed if you use the CCS output/input functions.
