davey
Need help sending a in16 from a master-PIC to a slave-PIC |
Posted: Thu May 04, 2006 1:31 pm |
Hi!
Right now I΄m using a PIC16F877A to generate a square-wave signal. This PIC-processor is also connected to a LCD display. What I want to do is send a 16-bit integer to one of two other identical PIC-processors(without LCD though) by i2c. This integer will tell a slave-PIC what freguency it should generate. That΄s it! I don΄t want to read anything from a either of the slave-PICs, just send an integer. I have the code for both master and slave(s). I would appreciate if someone could take a look at both and tell me the next step or what I΄ve done wrong so far.
Master-CODE: The things to look at here should be:
*the #use i2c(...) statement
*the function send_to_slave();
*the initialization i main()
#include <puls.H>
#fuses NOWDT
#use i2c(master,sda=PIN_C4,scl=PIN_C3)
int16 freq=20; //aktuell frekvens fφr mastern
int8 step=1; //Vald steg-nivε (1-4)
int8 channel=1; //Vald kanal (1-3)
byte pressed=0; //nedtryckt tangent
byte tmp4; //anv av lcd_write_as_hex
byte tmp3; //anv av timer1_isr()
byte tmp2; //anv av lcd_info()
byte tmp1;
int16 temp;
int16 temp2=0;
int16 temp3=0;
boolean write_zero=false;
struct lcd_map
int data:8;
boolean rs;
boolean enable;
boolean rw;
int unused:5;
lcd;
#byte lcd = 0x08
//CPU1 - Timer 1
int16 t1sv=3035; //Start-vδrde (65535-3035=62500) fφr Timer1 (ger 20Hz)
int16 t1svmod;
//Fφr de andra processorerna
int16 freq2=20; //frekvens - CPU2
int8 step2=4; //stegnivε - CPU2
int16 freq3=20; //frekvens - CPU3
int8 step3=1; //stegnivε - CPU3
//(((((((((((((((((((((((( INTERRUPTS ))))))))))))))))))))))))))))
#int_timer1 //KANAL 1
timer1_isr()
tmp3=TIMER1_CTRL;
TIMER1_CTRL=0x00;
t1svmod=t1sv;
TIMER_1_LOW=t1svmod&0x00FF; //laddar med den fφrsta byten av t1sv
t1svmod >>= 8; //shiftar 8 bitar till hφger
TIMER_1_HIGH=t1svmod&0x00FF;//laddar med den andra byten av t1sv
port_c ^= 1; //0->1 el. 1->0
TIMER1_CTRL=tmp3;
//%%%%%%%%%%%%%%%%%%%%%%%% FUNKTIONER %%%%%%%%%%%%%%%%%%%%%%%%%%%%
byte keyboard_in()
set_tris_b(0xF0);
port_b_pullups(true);
port_b = 0x0E;
if(!bit_test (port_b,7))
return 3;
if(!bit_test (port_b,4))
return 0;
if(!bit_test (port_b,5))
return 1;
if(!bit_test (port_b,6))
return 2;
port_b = 0x0D; //se ovan
return 7;
return 4;
return 5;
return 6;
port_b = 0x0B; //se ovan
return 11;
return 8;
return 9;
return 10;
port_b = 0x07; //se ovan
return 15;
return 12;
return 13;
return 14;
void lcd_waitbusy()
set_tris_d(0xFF);
lcd.rw = true;
delay_us(50);
if(bit_test(lcd.data,7)==0)
set_tris_d(0x00);
lcd.rw = false;
return;
void lcd_control(byte ctrl_in)
lcd_waitbusy();
lcd.rs=false;
lcd.rw=false;
lcd.data = ctrl_in;
lcd.enable=true;
delay_cycles(4);
lcd.enable=false;
delay_ms(2);
lcd.data = 0x00;
void lcd_data(byte data_in)
lcd_waitbusy();
lcd.rs=true;
lcd_waitbusy();
lcd.data=data_in;
lcd.enable=true;
delay_cycles(4);
lcd.enable=false;
delay_ms(2);
lcd.data = 0x00;
void lcd_write_as_hex(byte b)
tmp4=b>>4;
if(tmp4>9)
lcd_data(tmp4+0x37);
lcd_data(tmp4+0x30);
tmp4=b&0xF;
if(tmp4>9)
void calc_write_freq() //skriver ut frekvens pε LCD:n
switch(channel)
case 1:
temp2=freq;
case 2:
temp2=freq2;
case 3:
temp2=freq3;
temp3=temp2/1000;
if(temp3>0)
write_zero=true;
lcd_data(temp3+0x30);
temp3=temp3*1000;
temp2=temp2-temp3;
temp3=temp2/100;
if(temp3>0 || write_zero)
write_zero=true;
temp3=temp3*100;
temp2=temp2-temp3;
temp3=temp2/10;
temp3=temp3*10;
temp3=temp2-temp3;
write_zero=false;
lcd_data(' ');
lcd_data('H');
lcd_data('z');
void info_lcd() //Skriver ut vald kanal, stegnivε och frekvens till LCD:n
lcd_control(0x01);
lcd_data('K');
lcd_data('a');
lcd_data('n');
lcd_data('a');
lcd_data('l');
lcd_data(':');
lcd_write_as_hex(channel);
lcd_data(' ');
lcd_data('S');
lcd_data('t');
lcd_data('e');
lcd_data('g');
lcd_data(':');
switch(channel)
case 1:
lcd_write_as_hex(step);
case 2:
lcd_write_as_hex(step2);
case 3:
lcd_write_as_hex(step3);
lcd_control(0x41 + 0x80);
lcd_data('F');
lcd_data('r');
lcd_data('e');
lcd_data('k');
lcd_data('v');
lcd_data('e');
lcd_data('n');
lcd_data('s');
lcd_data(':');
calc_write_freq();
void send_to_slave() //I2C-funktion
switch(channel)
case 2: //skicka till slav-1
i2c_start();
delay_us(50);
i2c_write(0xa0); //adress
delay_us(50);
i2c_write(freq2>>8); //data
delay_us(50);
i2c_write(freq2&0x00FF);
i2c_stop();
case 3: //skicka till slav-2
i2c_start();
delay_us(50);
i2c_write(0x50); //adress
delay_us(50);
i2c_write(freq3>>8); //data
delay_us(50);
i2c_write(freq3&0x00FF);
i2c_stop();
default:
// MAIN
main()
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_port_a(NO_ANALOGS);
setup_psp(PSP_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_spi(spi_master | SPI_L_TO_H | spi_clk_div_4);
//====================== I/O ============================
set_tris_e(0x00); // PORT-E: alla utgεngar
set_tris_d(0x00); // PORT-D: alla utgεngar
set_tris_c(0x00); // PORT-C: alla utgεngar
//================== SETUP - Timer1 =====================
TIMER1_CTRL=0x11;
//=================== SETUP - LCD =======================
lcd_control(0x38);
lcd_control(0x06);
lcd_control(0x0C);
lcd_control(0x01);
info_lcd();
pressed=keyboard_in();
//UPP
if(pressed==1)
pressed=0;
switch(channel)
case 1:
if(step==4 || freq>7000) freq=freq+200;
else if(step==3 || freq>6000) freq=freq+100;
else if(step==2 || freq>5000) freq=freq+50;
else freq=freq+5;
if(freq>13000) freq=13000;
if(freq>40 && TIMER1_CTRL==0x11) TIMER1_CTRL=0x01;
temp=2*freq;
if(TIMER1_CTRL==0x11) temp=2495000/temp;
else temp=4990000/temp;
t1sv=65535-temp;
case 2:
if(step2==4 || freq2>7000) freq2=freq2+200;
else if(step2==3 || freq2>6000) freq2=freq2+100;
else if(step2==2 || freq2>5000) freq2=freq2+50;
else freq2=freq2+5;
if(freq2>13000) freq2=13000;
send_to_slave();
case 3:
if(step3==4 || freq3>7000) freq3=freq3+200;
else if(step3==3 || freq3>6000) freq3=freq3+100;
else if(step3==2 || freq3>5000) freq3=freq3+50;
else freq3=freq3+5;
if(freq3>13000) freq3=13000;
send_to_slave();
info_lcd();
//NER
if(pressed==2)
pressed=0;
switch(channel)
case 1:
if(step==4 || freq>7000) freq=freq-200;
else if(step==3 || freq>6000) freq=freq-100;
else if(step==2 || freq>5000) freq=freq-50;
else freq=freq-5;
if(freq<20) freq=20;
if(freq<=40 && TIMER1_CTRL==0x01) TIMER1_CTRL=0x11;
temp=2*freq;
t1sv=65535-temp;
case 2:
if(step2==4 || freq2>7000) freq2=freq2-200;
else if(step2==3 || freq2>6000) freq2=freq2-100;
else if(step2==2 || freq2>5000) freq2=freq2-50;
else freq2=freq2-5;
if(freq2<20) freq2=20;
send_to_slave();
case 3:
if(step3==4 || freq3>7000) freq3=freq3-200;
else if(step3==3 || freq3>6000) freq3=freq3-100;
else if(step3==2 || freq3>5000) freq3=freq3-50;
else freq3=freq3-5;
if(freq3<20) freq3=20;
send_to_slave();
info_lcd();
//STEP
if(pressed==5)
switch(channel)
case 1:
step++;
if(step>4) step=1;
case 2:
step2++;
if(step2>4) step2=1;
case 3:
step3++;
if(step3>4) step3=1;
info_lcd();
//KANAL
if(pressed==4)
channel++;
if(channel>3) channel=1;
info_lcd();
slave-CODE: In the interrupt-routine I just want to place the incoming 16-bit integer in the variable "freq".
#include <puls.H>
#fuses NOWDT
#use i2c(slave,sda=PIN_C4,scl=PIN_C3,address=0xa0,FORCE_HW)
int16 freq=20; //aktuell frekvens fφr denna slav
int16 temp;
//Timer 1
int16 t1svmod;
timer1_isr()
tmp3=TIMER1_CTRL;
TIMER1_CTRL=0x00;
t1svmod=t1sv;
TIMER1_CTRL=tmp3;
#int_ssp
receive_isr()
//ladda freq med mottaget vδrde
/*if(freq>40) TIMER1_CTRL=0x01;
else TIMER1_CTRL=0x11;
temp=2*freq;
t1sv=65535-temp;*/
/*if(bit_test(i2c_stat,6))*/ port_d=i2c_buff;
i2c_buff=0x00;
bit_clear(i2c_ctrl,3);
// MAIN
main()
setup_spi(spi_slave | SPI_L_TO_H | SPI_SS_DISABLED);
set_tris_c(0xFE); // PORT-C: alla ingεngar, utom C0(puls)
//========================I2C============================
enable_interrupts(INT_SSP);
TIMER1_CTRL=0x11;
while(1){};
PLEASE HELP ME!!!! :-(
/David[/code] |
Posted: Thu May 04, 2006 3:11 pm |
Your basic problem is that you are re-inventing the wheel several times
with your code. You are writing your own LCD and keypad drivers,
and also the i2c slave code. You should be using the CCS drivers
and example files:
KBD.C -- keypad driver
LCD.C -- LCD driver
EX_SLAVE.C -- Sample code for an i2c slave
Look for these files in:
c:\Program Files\PICC\Drivers
and
c:\Program Files\PICC\Examples
Also, you are doing a lot of time-consuming math in your INT_SSP
routine. You should only get the incoming i2c byte in that routine.
Don't do anything else. |
