structures and pointers again
Ted Ems
PostPosted: Tue May 16, 2006 3:17 pm     Reply with quote
After looking at all the forum questions and answers i'm still a little unclear what goes where. The code below has an array of structures ( data_array) and a single structure ( temp_data ). The send_serial routine needs to be able receive either a structure of the array or the temp_data structure. What do i need to place in the function prototype and in the send_serial routine?
#include "C:\CCS Projects\18f6620.h"
#opt 11
#zero_ram
#define Serial_RX_PIN       PIN_G2
#define Serial_TX_PIN       PIN_G1
#use rs232(baud=57600, xmit=Serial_TX_PIN, rcv=Serial_RX_PIN, errors, stream=Serial_Input,RESTART_WDT)
=====================What do i put in this function prototype?
void Send_Serial(            ,int8 i);          // send data out the serial port
struct data_packet
   int   error_code :5;             // zero if no errors
                                    // 1 if addr sent not equal to address rec
                                    // 2 if current pulse greater then >30 ma( dup addr )
                                    // 4 data not same as previous
                                    // 8 incorrect parity
   int   leds :3;
   int   extra_flags :3;
   int   drift :1;
   int   sensitivity :4;
   int   interrupt :1;
   int   extended_protocol :1;
   int   alarm_flag :1;
   int   parity   :1;
   int   input_command :4;
   int8 address_trans;
   int8  analog2;
   int8 analog_value;
   int8 device_type;
   int8 address_rec;
   int8  interrupt_alarm_address;
   struct data_packet data_array[127] ;
   struct data_packet temp_data;
int1 Service_serial(void){
      struct data_packet *ptr;
      int8  i;
      int16 eeprom2_address,data_ptr;
      int8  temp;
      switch (buffered_data[1]){ // PACKET TYPE
         case 16: // Normal type
            switch (buffered_data[5]){   //COMMAND
               case 01: // write data to eeprom
               case 02: // read data from scan
                  if (buffered_data[2]==255){ // is it a broadcast
                     for(i=1;i<127;i++){
                        if (data_array[i].error_code==0){
                           Send_Serial(&data_array[i],i);
                  else{
               case 03:  // write data to eeprom from scan
                  active_node_counter=0;
                  eeprom2_address=0;
                  for(i=1;i<127;i++){
                     if ((int8)data_array[i].error_code==0)
                        active_node_counter++;
                  init_ext_eeprom();
                  write_ext_eeprom(0,active_node_counter);   //save the number of active nodes
                  for(i=1;i<127;i++){
                     write_data_array_to_eeprom(&data_array[i],i);
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].interrupt;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].extended_protocol;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].alarm_flag;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].parity;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].input_command;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].error_code;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].leds;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].address_trans;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].analog_value;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].analog2;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].drift;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].sensitivity;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].device_type;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].address_rec;
                     write_ext_eeprom(eeprom2_address,data_array[nodeid].interrupt_alarm_address;
               case 04: // read data from eeprom
                     for(i=1;i<127;i++){
                        read_eeprom_to_temp_data(i);
                        Send_Serial(&temp_data,i);
                  else{
                     read_eeprom_to_temp_data(buffered_data[2]);
                     Send_Serial(&temp_data,buffered_data[2]);
                  case 255:
                     reset_cpu();
               default:
         default :
void read_eeprom_to_temp_data(int8 i){
      int16 eeprom_address2;
      int8 a[9];
      int8 j;
      eeprom_address2=1 + (i-1)*sizeof(temp_data);
      for(j=0;j<sizeof(temp_data);j++){
         a[j]=read_ext_eeprom(eeprom_address2);
         eeprom_address2++;
     memcpy(&temp_data,a,sizeof(temp_data));
void write_data_array_to_eeprom(int8 *tp,int8 i){
      int8   *ptr;
      int8   q,j;
      ptr=tp;
          q=*ptr++;
         write_ext_eeprom(eeprom_address2,q);
         eeprom_address2++;
================ What do i put in here?
void Send_Serial(          ,i){
      int8  temp,temp2;
      fprintf(serial_input,"NODE# %u\r",i);
      temp=0;
      if (ptr->interrupt)           // can't force a type conversion on int1 within a struct.
         temp=1;                                   // this sucks but it works
      fprintf(serial_input,"Interrupt %u\r",temp);
      temp=0;
      if (ptr->extended_protocol)
         temp=1;
      fprintf(serial_input,"Extended protocol %u\r",temp);
      temp=0;
      if (ptr->drift)
         temp=1;
      fprintf(serial_input,"Drift %u\r",temp);
      fprintf(serial_input,"Sensitivity %u\r",(int)ptr->sensitivity);
      temp=0;
      if (ptr->alarm_flag)
         temp=1;
      fprintf(serial_input,"Alarm flag %u\r",temp);
      fprintf(serial_input,"Parity %u\r",(int)ptr->parity);
      fprintf(serial_input,"Input command %u\r",(int)ptr->input_command);
      fprintf(serial_input,"Error code %u\r",(int)ptr->error_code);
      fprintf(serial_input,"Led state of last scan %u\r",(int)ptr->leds);
      fprintf(serial_input,"Address trans %u\r",ptr->address_trans);
      fprintf(serial_input,"Analog2 %u\r",ptr->analog2);
      fprintf(serial_input,"Analog1 %u\r",ptr->analog_value);
      fprintf(serial_input,"Device type %u\r",ptr->device_type);
      fprintf(serial_input,"Address_rec %u\r",ptr->address_rec);
      fprintf(serial_input,"Interrupt_alarm %u\n\r",ptr->interrupt_alarm_address);
Mark
PostPosted: Tue May 16, 2006 6:03 pm     Reply with quote
Ted Ems
pointers and structures
PostPosted: Wed May 17, 2006 5:38 am     Reply with quote
Mark
The compiler returns with an error message saying "Function definition different from previous". Got any suggestions
Re: pointers and structures
PostPosted: Wed May 17, 2006 6:20 am     Reply with quote
This error means your function declaration (at the start of the program) is different from the implementation (your actual function).
Mark
PostPosted: Wed May 17, 2006 6:31 am     Reply with quote
You also need to declare the struct before your function prototype.
PostPosted: Wed May 17, 2006 6:45 am     Reply with quote
Remember the structure type, must be declared, before the prototype function.
As an 'aside', there is no point in using an int1 return fom a function. The compiler always has to return at least a byte. The effect varies with compiler versions, but on some, using int1, actually results in slightly bulkier code, as the compiler evaluates the logic, converts it to a byte, then tests this again on the return. Like you, I felt it seemed logical to return a single bit for a flag, but I found on one particular program the result got larger. Inspecting the .LST, showed what was happening.
Ted Ems
PostPosted: Wed May 17, 2006 8:24 am     Reply with quote
I've looked at this code off and on for a couple days. Did not even occur to me that the declaration was in the wrong place.
Thanks for all the help
