I'm working on a datalogger with the PIC18F252. For speed during datatransfer I need a 20 MHz crystal, for low power consumption when logging I want to use a 32kHz crystal.
I found the OSCSEN fuse to enable swithing and I studied the relevant parts of sections 2, 11 and 19 of the datasheet but I can't do the trick until now.
Is there somebody here who can help me a step further with this?
Look in the 18F252.H file, in the section titled:
"Constants used in setup_oscillator()"
It lists the constants that you can use with the setup_oscillator()
function with the 18F252.
