What is wrong for this SPI and M25P40 Flash Memory ???
cfernandez
PostPosted: Mon May 01, 2006 2:36 pm     Reply with quote
I use the M25P40 Flash memory from ST in my project and I have this source code but the SPI hardware function NOT WORK!!, the bit banging WORK!!.
Can you tell me that is wrong in this code??.
The M25P40 work in mode 0,0 & 1,1 and The most significant bit is send first. The SPI_WRITE send first the MSB or LSB ?????
Thank you very much for help me!!
void SPIFLASH_Init( void )
   #ifdef SPIFLASH_SPI_FUNC
      setup_spi( SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4 );
   #endif
   output_high( SPIFLASH_SELECT_BANK0 );
   output_high( SPIFLASH_SELECT_BANK1 );
   output_low( SPIFLASH_DI );
   output_low( SPIFLASH_CLK );
#ifdef SPIFLASH_BIT_BANGING
   void SPIFLASH_Out( char *sData, int16 lLen )
      int      iBit;
      int16   lPtr;
      char   cByte;
      for ( lPtr = 0 ; lPtr < lLen ; lPtr++ )
         cByte = sData[ lPtr ];
         for( iBit = 0 ; iBit < 8; iBit++ )
            output_bit( SPIFLASH_DI, shift_left( &cByte, 1, 0 ) );
            output_high( SPIFLASH_CLK );      //data latches
            output_low( SPIFLASH_CLK );         //back to idle
   void SPIFLASH_In( char *sData, int32 dLen )
      int      iBit;
      int32   dPtr;
      char   cByte;
      for ( dPtr = 0 ; dPtr < dLen ; dPtr++ )
            shift_left( &cByte, 1, input( SPIFLASH_DO ) );
         sData[ dPtr ] = cByte;
#else
      int      iBit;
      int16   lPtr;
      char   cByte;
            shift_right( &cByte, 1, bit_test( sData[ lPtr ], iBit - 1 ) );
         spi_write( cByte );
      int      iBit;
      int32   dPtr;
      char   cByte;
         cByte = spi_read( 0xFF );
            shift_right( &sData[ dPtr ], 1, shift_left( &cByte, 1, 0 ) );
#endif
int SPIFLASH_Status( void )
   int      iCmd, iStatus;
   iCmd = SPIFLASH_INST_RSR;
   output_low( SPIFLASH_SELECT_BANK0 );
   SPIFLASH_Out( &iCmd, 1 );
   SPIFLASH_In( &iStatus, 1 );
   return iStatus;
PostPosted: Tue May 02, 2006 12:41 am     Reply with quote
I don't know why you're doing all the shifting stuff in the hardware
version. It should be something like this:
void SPIFLASH_Out(char *sData, int16 lLen )
int16 lPtr;
for(lPtr = 0 ; lPtr < lLen; lPtr++)
    spi_write(sData[lPtr]);
Also the SPIFLASH_In() routine needs to be fixed in a similar way.
cfernandez
PostPosted: Tue May 02, 2006 6:54 am     Reply with quote
Dear PCM,
The SPI_Write send firs the Most Significant Bit (7) or LSB ?
Thank you very much!!!!!!
PostPosted: Tue May 02, 2006 9:40 am     Reply with quote
Look in the data sheet for your PIC. You didn't say what PIC you're
using, but the section will probably be called:
"Master Synchronous Serial Port (MSSP)"
Then in that section, find the timing diagram labeled:
SPI MODE TIMING, MASTER MODE
That diagram shows the bits. The bit on the left side of the
timing diagram is the one that comes out first.
Read that section in the data sheet and you will learn the answer.
cfernandez
PostPosted: Tue May 02, 2006 12:33 pm     Reply with quote
PCM
You are a MONSTER!!!!!!!!!
Thank you very much!!!!!!!!!!
