LCD Inop After Sleep
jecottrell
PostPosted: Sat Apr 29, 2006 4:01 pm     Reply with quote
Hello All,
18F4620
3.236
I've got a character LCD connected to port_d and I'm using the standard lcd.c driver. When I put the PIC to sleep the LCD won't work upon wake-up. I init it and do everything just like upon power up.
However, if I reset_cpu() I can get the LCD to work, but that generates another problem. I use a momentary switch to interrupt RB6 to wake the processor. When I push the button to wake the CPU, the interrupt 'hangs' i.e. fires continuously.
If I disable the portb interrupts in the ISR the interrupt no longer 'hangs', but I can never get the portb interupt re-enabled....
Any ideas?
Thanks,
John
PostPosted: Sat Apr 29, 2006 11:03 pm     Reply with quote
The test program shown below works OK. I tested it on a PicDem2-Plus,
which has the LCD on pins D0-D3 and A1-A3. To get the INT_RB
interrupt, I pulled out the ICD2 connector and jumpered the push-button
switch on B0 over to pin B7. When it's in Sleep mode, I push the
button and it displays this on the LCD:
Wake up
Hello World
Sleeping
I can do that repeatedly.
#include <16F877.H>
#include "flex_lcd.c"
#int_rb
void rb_isr(void)
disable_interrupts(INT_RB);
int8 i;
int8 c;
lcd_init();
port_b_pullups(TRUE);
   lcd_putc("\fHello World");
   delay_ms(2000);
   c = input_b(); // Clear "change condition" on Port B
   clear_interrupt(INT_RB);    // Clear RBIF flag
   enable_interrupts(INT_RB);  // Enable RB interrupts
   lcd_putc("\fSleeping");
   sleep();
   lcd_putc("\fWake up");
   delay_ms(2000);
