pic power and frequency control!
pcmguy
PostPosted: Fri Apr 28, 2006 8:02 pm     Reply with quote
Hi all, can anyone answer me:
1. What is the pic power consumtion and crystal speed relation? e.g. if same project i use pic16f84 with 4MHz and 20MHz, how much power will safe from using 4MHz? 1, 2, 4X?
2. If i use pic16f84A, what crystal speed can use? 4MHz? 20MHz? What's about if I use pic16f84-20IP? can I use 4MHz crystal?
3. If I want use switch input for my PIC, normally I use 10K ohm resistor to pullup, may I know what is the maximum ohm I can put? 4k7? 100k?
Thanks! Smile
Yours PCM GUY,
Mark
PostPosted: Fri Apr 28, 2006 8:42 pm     Reply with quote
All of your questions can be answered by reading the datasheet.
rberek
PostPosted: Fri Apr 28, 2006 8:50 pm     Reply with quote
Also note that the top speed of the PIC16F84 is 10 MHz. There is no PIC16F84-20IP. There is a PIC16F84A-20I/P
The max frequency of a PIC is given on the first page of its datasheet.
r.b.
