Port A on PIC16F876
vik
Port A on PIC16F876
PostPosted: Fri Apr 28, 2006 12:09 pm     Reply with quote
hi,
Could some one tell me what is the best way to configure PORT A as digitalouts on the PIC16f876. The datasheet says that the ports are configured as analog inputs by default. Presently I am using the following to configure PORTA as digitals. I am not sure if I need to add something more.
#use fast_io(A)
main(){
set_tris_A(0x00);
SETUP_ADC(ADC_OFF);
while();
thks
PostPosted: Fri Apr 28, 2006 2:21 pm     Reply with quote
That's one way to do it. An easier way is to get rid of the #fast_io()
statement and use the CCS pin i/o functions, such as output_low,
output_high, input(), output_float(), output_a(), input_a(), etc.
In standard i/o mode, the compiler will automatically set the correct TRIS
for you. Standard i/o mode is the default mode of the compiler. You
don't have to specify it.
