rrb011270
#int_ad Help? |
Posted: Wed Feb 11, 2004 5:11 am |
Mabuhay!
I am using the #int-AD service routine of a PIC18F452 at 20MHz. I am using a variable power supply as my analog voltage input to replicate the changes in the analog input to the PIC ADC AN0 channel
Unfortunately, I read zero result even if I vary the power supply output voltage from 5V to 0V or vice versa. Is there something wrong with my code listed below? Or maybe I miss something?
BTW, I use two 5V power supply here: one for the PIC18F452 and the other for my analog voltage.
Any help will do? Please comment on this?
Thank you.
The code:
#include <18F452.H> // Target PIC Microcontroller IC
#device *=16 ADC=10 // use a 16-bit pointer & 10bit A/D
#fuses HS,NOPROTECT,NOWDT // PIC MCU Configuration
#use delay(clock=20000000) // 20MHz Crystal clock speed
#use rs232(baud=115200,parity=N,xmit=PIN_B3,rcv=PIN_B2,bits=8)
// Include Files //
#include <LCD.C>
// PIC18F452 Config Register //
unsigned char ADRESL;
#locate ADRESL=0x0FC3
unsigned char ADRESH;
#locate ADRESH=0x0FC4
unsigned char PIR1;
#locate PIR1=0x0F9E
struct {
unsigned char TMR1IF:1;
unsigned char TMR2IF:1;
unsigned char CCP1IF:1;
unsigned char SSPIF :1;
unsigned char TXIF :1;
unsigned char RCIF :1;
unsigned char ADIF :1;
unsigned char PSPIF :1;
} PIR1bits;
#locate PIR1bits=0x0F9E
unsigned char ADCON0;
#locate ADCON0=0x0FC2
struct {
unsigned char ADON :1;
unsigned char ADNONE:1;
unsigned char GODONE:1;
unsigned char CHS0 :1;
unsigned char CHS1 :1;
unsigned char CHS2 :1;
unsigned char ADCSO :1;
unsigned char ADCS1 :1;
} ADCON0bits;
#locate ADCON0bits=0x0FC2
unsigned char ADCON1;
#locate ADCON1=0x0FC1
struct {
unsigned char PCFG0 :1;
unsigned char PCFG1 :1;
unsigned char PCFG2 :1;
unsigned char PCFG3 :1;
unsigned char ANONE1:1;
unsigned char ANONE2:1;
unsigned char ADCS2 :1;
unsigned char ADFM :1;
} ADCON1bits;
#locate ADCON1bits=0x0FC1
// Defines and Macros //
// Six (6) Most Significant bits of ADRESH are read as ’0’
#define ADC_RIGHT_JUSTIFY 1
// Six (6) Least Significant bits of ADRESL are read as ’0’
#define ADC_LEFT_JUSTIFY 0
// Global Flag Variables //
int1 glADCdone = 0; // A/D done conversion flag bit
// Global Variables //
unsigned int16 gi16ADCresult; // A/D result value after conversion
// Interrupt Service Routines //
The data sheet says there must be a delay of 2 x Tad
after a conversion. Since we're using a Tad of 3.2 usec,
this delay must be 2 x 3.2 = 6.4 usec. But we know that the
CCS interrupt handler takes at least that long to go in
and out of this interrupt routine (with our 20 MHz crystal),
so we don't need to put in a line of code to do the delay.
#int_ad // ADC interrupt service routine
void adc_isr()
// read the 10-bit ADC result
// this requires reading the high and low bytes of the
// ADC register, and putting them into a 16-bit variable
gi16ADCresult = (ADRESH<<8);
gi16ADCresult |= ADRESL;
glADCdone = 1; // ADC conversion complete
while (PIR1bits.ADIF) // check if ADIF is set
PIR1bits.ADIF = 0; // set ADIF to zero
// End Interrupt Service Routines //
// MCU Initialization Routines //
void init_chip() { // Initialize the MCU Chip
lcd_init(); // LCD should be initialized first
lcd_init(); // Init LCD again, coz sometimes can't initialize LCD
lcd_init(); // Once more, to be sure LCD gets initialized
setup_adc_ports(RA0_RA1_RA3_ANALOG); // setup the ADC analog pins
// with a 20MHz clock, we divide the oscillator by 64
// to get an ADC clock of 312.5KHz, so Tad=3.2usec
setup_adc(ADC_CLOCK_DIV_64); // configure the ADC clock to 3.2usec
set_adc_channel(0); // specify ADC channel to use (PortA0)
ADCON1bits.ADFM = ADC_RIGHT_JUSTIFY;
PIR1bits.ADIF = 0; // clear ADC interrupt before enabling
enable_interrupts(int_ad); // enable ADC interrupt
enable_interrupts(global); // enable global interrupt
//End MCU Initialization Routines//
// Main Program
main()
init_chip(); // Initialize the MCU Chip
lcd_putc("\fADC Demo");
gi16ADCresult = 0; // initialize the ADC result variable to zero
delay_us(20); // wait for ADC aquisition time
ADCON0bits.GODONE = 1; // start an ADC conversion
while (TRUE)
if (glADCdone) // ADC conversion completed
glADCdone = 0; // prevent multi-trigger of ADC conversion
printf("ADC Result = %lx\n\r",gi16ADCresult); // print the result
// for demo purpose delay 1sec. for screen updating with
// the new ADC result
ADCON0bits.GODONE = 1; // start another ADC conversion
// End Program
[/img] |
Posted: Wed Feb 11, 2004 6:23 am |
To say that you seem to be working very hard to do something that the compiler allready does for you, is perhaps an understatement...
The READ_ADC function, has three variables. ADC_START_ONLY, and ADC_READ_ONLY, allow the standard functions to be used to cover what you are doing. ADC_START_AND_READ, gives the 'default' behaviour.
So, you only need in the interrupt code:
void adc_isr()
gi16ADCresult = READ_ADC(ADC_READ_ONLY);
The global handler routine automatically clears the interrupt flag.
In the main code, you can use:
[code]
//The default is to right justify
// Main Program
main()
READ_ADC(ADC_START_ONLY); // start an ADC conversion
while (TRUE)
READ_ADC(ADC_START_ONLY); // start another ADC conversion
rrb011270
Posted: Wed Feb 11, 2004 8:13 am |
Thanx u for the immediate response...
I'll try this code tommorrow... coz its 11:00pm here in the Philippines...
May the force be with you...  |
Re: #int_ad Help? |
Posted: Wed Apr 26, 2006 11:20 am |
rrb011270 wrote: | Mabuhay!
Thank you.
The code:
// Include Files //
#include <LCD.C>
unsigned char PIR1;
#locate PIR1=0x0F9E
struct {
} PIR1bits;
struct {
} ADCON0bits;
struct {
} ADCON1bits;
void adc_isr()
// Main Program
main()
while (TRUE)
// End Program
[/img] |
I have the same problem |
