URGENT
MARC
URGENT
PostPosted: Tue Apr 25, 2006 1:59 pm     Reply with quote
I am using a PIC16F874. When I program the PIC it shows the error-There are more program codes at <EEO> after <EDF>.
Some part of my code doesnot work.is it due to this?
How do i fix this??
thanx
marc
my code:
// You must include the header file for the PIC
#include <16F874.H>
// Setting the number of Hz the PIC is at
// Initializing variables
char event;
int distance, count;
float temp;
enable_interrupts(INT_rb);
enable_interrupts(global);
output_low(PIN_E0);
count = 0;
while(1){
if(event == 's' || event == 'r' || event == 'g' || event == 'h'){
while(event == 's')
count = 2000;
//motor forward
output_high(PIN_D3);
output_low(PIN_D2);
delay_ms(1);
//count = 1000; // worked with 0
if(event == 'g')
//Turn transmitter on
output_high(PIN_E0);
temp = 9*((4000 + count)/(2000));
distance = (int) temp;
switch(distance) //outputting data to wireless
case 65 :
output_high(PIN_C0);
output_high(PIN_C6);
case 64 :
case 63:
output_high(PIN_C5);
output_high(PIN_C4);
output_high(PIN_C3);
output_high(PIN_C2);
output_high(PIN_C1);
case 62:
case 61:
case 60:
case 59:
case 58:
case 57:
case 56:
case 55:
case 54:
case 53:
case 52:
case 51:
case 50:
case 49:
case 48:
case 47:
case 46:
case 45:
case 44:
case 43:
case 42:
case 41:
case 40:
case 39:
case 38:
case 37:
case 36:
case 35:
case 34:
case 33:
case 32:
case 31:
case 30:
case 29:
case 28:
case 27:
case 26:
case 25:
case 24:
case 23:
case 22:
case 21:
case 20:
case 19:
case 18:
case 17:
case 16:
case 15:
case 14:
case 13:
case 12:
case 11:
case 10:
case 9:
case 8:
case 7:
case 6:
case 5:
case 4:
case 3:
case 2:
case 1:
case 0:
output_low(PIN_C7);
output_low(PIN_C6);
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2);
output_low(PIN_C1);
output_low(PIN_C0);
default :
output_high(PIN_C7);
output_low(PIN_D3);
output_high(PIN_D2);
if (event == 'h'){
output_low(PIN_D3); // stop motor
output_low(PIN_D2);
//motor forward
//output_high(PIN_D3);
//output_low(PIN_D2);
//delay_ms(25);
//output_low(PIN_D3); // stop motor
output_high(PIN_C7); //operation complete
//reset values
output_low(PIN_C7);
output_low(PIN_C6);
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2);
output_low(PIN_C1);
output_low(PIN_C0);
//turn off transmitter/
output_low(PIN_E0);
count = 0;
distance = 0;
event = 'r';
#int_rb
rb_isr ( )
// Initializing everything
byte changes;
int last_b;
int port_b;
changes = last_b ^ port_b;
last_b = port_b;
// if bob hit grain
if (!input(PIN_b6)){event = 'g';
// if bob is at housing
if (!input(PIN_b5)){event = 'h';
// if start
if (!input(PIN_b4)){event = 's';}
//debounce
PostPosted: Tue Apr 25, 2006 2:07 pm     Reply with quote
"Urgent" probably means homework. But here's one small tip:
You have tons and tons of code which outputs the 'distance' to Port C.
Why not just do it with one line of code ? Like this:
output_c(distance);
Douglas Kennedy
PostPosted: Wed Apr 26, 2006 8:04 am     Reply with quote
Yep it's getting to the end of the school year and this board will be expected to do term papers. Many might think that due to the large number of repetitive questions ( Ex RS232 issues) that the search function on this board must be broken.
