SPI Problem
jecottrell
SPI Problem
PostPosted: Tue Apr 25, 2006 9:14 am     Reply with quote
I am writing some values to registers on an MCP23S17 SPI port expander and for some reason the SPI comms are causing a problem.
If I write 0b01010101, when I read the value back I get 0b10101010.
When I write 0b00001111, when I read the value back I get 0b10001111.
When I write 0b11110000, when I read the value back I get 0b11111000.
Here's my SPI setup:
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_64);
Any ideas?
UPDATE:
It appears it's a spi_read problem because the ports are set correctly. It's just when I read back the value I get the wrong info.
PostPosted: Tue Apr 25, 2006 10:57 am     Reply with quote
Try using CharlieU's method of defining the SPI modes, as shown
in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=26662&start=4
Instead of using "SPI_H_TO_L", use his "SPI_MODE_0_0" constant
in setup_spi().
jecottrell
PostPosted: Tue Apr 25, 2006 11:12 am     Reply with quote
PCM,
I remember seeing that post previously. I didn't put two and two together.
It seems to have solved the problem.
Thanks!
John
