MPLAB is working fine when i use the PIC16F877A. therefore, i think if it is not installed properly both will not work. i'm using MPLAB V7.31 and CCS PCW C Compiler, Version 3.124.
is it possible to use the ICD2 with the PCW IDE?
Posted: Tue Apr 25, 2006 12:50 pm
The CCS IDE only directly supports their own CCS ICD debugger.
