Bingo Guest
| Change I2C Speed |
Posted: Tue Apr 25, 2006 5:55 am |
How change I2C speed in program
#include <18F452.h>
#use delay(clock=2000000)
#use I2C(MASTER, sda=PIN_C4, scl=PIN_C3, Fast)
main(){
void pump1(void){
change speed I2C Slow
void pump2(void){
change speed I2C Fast
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Tue Apr 25, 2006 6:25 am |
Set the SSPADD register to the value that will give you your new required buad rate. Check the datasheet of the PIC you are using to determine that value.
r.b. |
JPA Guest
Posted: Wed Apr 26, 2006 2:05 am |
The compiler can handle this, with HW and Software I2C:
| Code: | | #use i2c(MASTER, SDA=I2C1_SDA, SCL=I2C1_SCL, FAST=50000) |
