PIC18F422 and MPLAB Error
Ahmed
PostPosted: Tue Apr 25, 2006 12:11 pm     Reply with quote
I'm using PIC18F442 and when i'm comipling the code from MPLAB i get the following error
Executing: "E:\PICC\Ccsc.exe" biometrics_v3.c -CC -fINHX8M -p18F442 -IE:\PICC\Project Programs -a -L -Q -V -FM
Error[24] 18F442.h 2 : Unknown device type
when i use the PCM C Compiler IDE the code compiles as shown
Compiling: biometrics_new.c
in e:\picc\project programs\
Lines: 1940
Linking
Writing biometrics_new.HEX
Writing biometrics_new.SYM
Writing biometrics_new.LST
Writing biometrics_new.COD
Writing biometrics_new.TRE
Writing biometrics_new.STA
Memory usage:
ROM=26%
RAM=7% - 18%
No Errors.
do anybody knew the reason of the error generated by the MPLAB or how can i download the code after compiling it using PCW IDE. (i'm using ICD2)
PostPosted: Tue Apr 25, 2006 12:30 pm     Reply with quote
Make sure you have CCS installed correctly, and that you have
selected the correct "Tool Suite", etc. See this FAQ article:
http://www.ccsinfo.com/faq.php?page=ccs_mplab6
Ahmed
PostPosted: Tue Apr 25, 2006 12:44 pm     Reply with quote
MPLAB is working fine when i use the PIC16F877A. therefore, i think if it is not installed properly both will not work. i'm using MPLAB V7.31 and CCS PCW C Compiler, Version 3.124.
is it possible to use the ICD2 with the PCW IDE?
PostPosted: Tue Apr 25, 2006 12:50 pm     Reply with quote
The CCS IDE only directly supports their own CCS ICD debugger.
You have to use MPLAB with ICD2.
