Code conversion
deltatech
Code conversion
PostPosted: Sat Apr 22, 2006 12:46 pm     Reply with quote
Hi does any know how to convert this code to ccs code ? i want scan knight rider light left to right . I have tried but faild ! Sad
[/code]void main()
trisb = 00000000b; // set port b to output
trisa= 11111111b; // set port a to inputs
char data = 00000001b; // initial data.
bool movingRight = true;
while( 1 )
bit button = porta.0;
// portb = 00111111;//data; // update port
delay_ms( 50 );
// if (button==1)
portb=data; // update port
if( movingRight )
data <<= 1;
if( data.5 ) // msb set
movingRight = false;
data >>= 1;
if( data.0 ) // lsb set
movingRight = true;
PostPosted: Sat Apr 22, 2006 1:59 pm     Reply with quote
This should do want you want. Uncomment to control activity on port B through a logic level input to pin A0.
#include <your_mcu_here.h>
#use delay(clock=your_oscillator_frequency_here)
   int data;
   int1 movingRight;
   set_tris_a(0xFF);      // Set port A to all input
   set_tris_b(0x00);      // Set port B to all output
   data = 1;
   movingRight = FALSE;
//      if(input(PIN_A0))
         output_b(data);
         if(movingRight)
            data >>= 1;
            data <<= 1;
         if(data == 0x80)
            movingRight = TRUE;
         else if(data == 0x01)
         delay_ms(50);
deltatech
PostPosted: Sat Apr 22, 2006 4:10 pm     Reply with quote
Who ever you are . Your are great many thanks . I spent all day and i couldnt get it to work . but then i am a newbie . Once again many thanks Smile
