Hernán Guest
| interrupt poblem |
Posted: Mon Apr 17, 2006 4:59 am |
I'm a complete newbie in programming PICs, I started with them a few weeks ago, so I'm sorry if my question seems to basic for most of you, but here we go:
I'm working with a 18f8722, but I'm not able to make the rda interrupt work properly. As soon as I enable the interrupt the program goes crazy and does nothing more. Before I enable the interrupt I clear it, and I clear the RCREG register too, but that doesn't seem to be enough. What am I doing wrong or what am I forgeting?
Another problem, which have nothing to do with the previous one, is that a program that I made seems to work perfectly with one of the rs232 ports in the PIC, but when I try the same program with the other port (using in this second port the same configuration as in the other one) it doesn't work. Are there any differences between both ports? I couldn't find any in the datasheet, but as stated before, I'm a newbie, and I may well be skipping something.
Help with any of those problems will be appreciated.
Thank you. |
Posted: Mon Apr 17, 2006 6:27 am |
What is the receive data line 'idling' at?. This must idle 'high', or you will get an interrupt every character time continuously.
Second, you must read the character inside the interrupt routine, or the interrupt will continuously be re-called.
Does you handler have any ability to handle 'overrun errors'?.
Add the 'ERRORS' statement to the RS232 setup, if it is not already there. If you are reading RCREG yourself, rather than using getc with 'ERRORS' enabled, and the overrun error is set, you have to turn off the UART, and re-enable it, to clear this condition. I'd suggest adding the ERRORS statement, and reading RCREG, by using 'if kbhit', and if a character is present calling a dummy getc, which will clear this error.
Hernán Guest
Posted: Mon Apr 17, 2006 8:17 am |
| How do I know if the receive data line idles high or low? I didn't configure that, so I suppose it's default now, but really have no idea about it. |
Posted: Mon Apr 17, 2006 8:51 am |
Depends on the hardware you have attached.
No one else can know.
Basically if you have an incoming RS232 line, this requires an inverting line receiver, to change it to TTL serial, which the chip expects. If the source is already 'TTL serial', you have to check the manufacturers data sheet to find out which logic level the serial is using.
