internal oscilator PIC16F88
andreluizeng
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Apr 17, 2006 12:33 pm     Reply with quote
Hi people, how can i set the internal oscilator for pic16f88 ? its datasheet says that it has an internal oscilator divided by blocks, but theres no valid fuses that i can use.
att.
André
Andre
PostPosted: Mon Apr 17, 2006 12:41 pm     Reply with quote
Look in the list of fuses near the start of the 16F88.H file.
You will see these fuses:
INTRC and INTRC_IO
Here is an example program:
http://www.ccsinfo.com/forum/viewtopic.php?t=22955&start=1
andreluizeng
PostPosted: Mon Apr 17, 2006 12:46 pm     Reply with quote
i think that my compiler is older than yours.
i've tried to use INTRC INTRC_IO and it didnt work.
my compiler is version 3.2 but, i've got a code in this forum that set its up to internal oscilator with 4MHZ.
look at that:
#use delay (clock = 4000000, RESTART_WDT)
#byte OSCCON = 0x8F
OSCCON = 0x6C;
that is it.
thanks for the help.
regards.
André
Andre
