i am using a pic16f914 and am setting values into eeprom thru view/eeprom then i set the values i want in the addresses needed. Upon powering up my circuit the values seem to be other than what i stored before compilation, however once i set the values in my project when PIC is running they are stored correctly and it works fine. I am storing the values of 00 from adress 00 to 0f. What could be causing the eeprom to store data other than the zeros i set there.
Thanks in advance!
Pedro
#FUSES INTRC //Internal RC Osc
#FUSES PUT //Power Up Timer
#FUSES BROWNOUT //Brownout reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#int_timer0
