mikebruce
Multiple Keypress detection |
Posted: Wed Apr 12, 2006 8:50 am |
Hi All,
I am looking for some advice. I am requiring to control a device that can move forward/backwards as well as left/right. I am using an adapted version of the generic keyscan routine (as I have a 32 key, keypad) supplied with the CCS complier and it works fine, I now need to modify it to allow me to detect when I am pressing for example Forward and Right or Forward and Left etc and not allow for example both Forward and Backwards to be pressed at the same time.
Any advice would be greatly appreciated many thanks,
Mike ![Very Happy](images/smiles/icon_biggrin.gif) |
KamPutty Guest
Posted: Wed Apr 12, 2006 10:34 am |
Hi Mike,
When I want to detect keys, I handle it in 2 steps.
#1. The first step just is an ISR etc that just detects keys being pressed and updated a mask for each key.
#2. I have another routine (can be ISR, user controlled etc) that reads the keyboard mask that was updated by #1., and based on that I can apply rules. If the Up and Down are both pressed, do "this", else do "that". The ISR (#1) also detects the first key pressed, so I can determine if Up and Down where both pressed, which was really first.
Make sense?
By using masks, it's very easy to check for valid keys entries as all I am doing is checking against a valid key combo.
Here is what I have in my ISR...
// update buttons only after 'n' mseconds
keyCounter++;
if(keyCounter>INTS_PER_KEY_POLL)
keyCounter=0;
// lets get the current state - remember to invert them
buttons.physicalButtons.singleButton.button1=~input(BUTTON_1_PIN);
buttons.physicalButtons.singleButton.button2=~input(BUTTON_2_PIN);
buttons.physicalButtons.singleButton.button3=~input(BUTTON_3_PIN);
buttons.physicalButtons.singleButton.button4=~input(BUTTON_4_PIN);
buttons.physicalButtons.singleButton.button5=~input(BUTTON_5_PIN);
buttons.physicalButtons.singleButton.button6=~input(BUTTON_6_PIN);
I check against 6 buttons.
When I wish to check for any buttons, I can do this
// A?
if(buttons.activeButtons.allButtons==BUTTON_A)
currentProfile=0;
loadProfile(currentProfile);
return YES;
// A+B?
else if(buttons.activeButtons.allButtons==(BUTTON_A+BUTTON_B))
currentProfile=1;
return YES;
Here is the struct that I use...
Code: | struct Buttons
// true active button state
union
int8 allButtons;
struct
int1 button1; // true state of button 1
int1 button2; // true state of button 2
int1 button3; // true state of button 3
int1 button4; // true state of button 4
int1 button5; // true state of button 5
int1 button6; // true state of button 6
} singleButton;
} physicalButtons;
// program active buttons, buttons we allow
union
int8 allButtons;
struct
} singleButton;
} activeButtons;
int8 firstButton;
struct Buttons buttons;
I have 2 parts to the struct, the actual values (this that are truely pressed), and then the settings of what I allow (this way I can select what to act on vs. what is physically pressed)
Hope it helps!
~Kam (^8* |
treitmey
Posted: Wed Apr 12, 2006 11:06 am |
I would tackle the problem differently.
I know this isn't your setup, But you will get the idea.
Just define another key for valid options.
I would think of it like a game controler.
1==Forward, Left
2==Forward
3==Forward, Right
6==Right
9==Backword, Right ...
This way you don't have to detect the multi-press |
Mark
Posted: Wed Apr 12, 2006 11:53 am |
Since you have 4 switches that represent direction, there are a possible 16 combinations. Only 8 of these are correct, 8 are invalid. I would create an enum of all 16 values (17 if you count no keypress). Let's say the four keys were:
-1-
2-3
-4-
Therefore:
Up would be 0b00000001 - d'1
Left would be 0b00000010 - d'2
Right would be 0b00000100 - d'4
Down would be 0b00001000 - d'8
Up-Left would be 0b00000011 - d'3
Up-Right would be 0b00000101 - d'5
Down-Right would be 0b00001100 - d'12
Down-Left would be 0b00001010 - d'10
so
Code: | enum Keys
KEY_NONE,
KEY_UP,
KEY_LEFT,
KEY_UP_LEFT,
KEY_RIGHT,
KEY_UP_RIGHT,
KEY_INVALID1,
KEY_INVALID2,
KEY_DOWN,
KEY_INVALID3,
KEY_DOWN_LEFT,
KEY_INVALID4,
KEY_DOWN_RIGHT,
KEY_INVALID5,
KEY_INVALID6,
KEY_INVALID7,
KEY_INVALID8,
Now you can just read the value of those 4 switches and process them with a switch statement.
Note that depending on how your switches are connected, your results will be different. |
