multiple rs232
ninebarmaximus
multiple rs232
PostPosted: Tue Apr 11, 2006 7:07 am     Reply with quote
am i able to use 2 rs232's on the one pic,
like could i have two declarations for using the rs232 on different pins?
and if i did that how would i specify which rs232 i wanted to use would it be something really simple like
putc(PIN_c7) for one device(obviously after declaring c7 as an output pin
and
putc(PIN_a2) for the other
is this possible or am i living in a fantasy land
cheers
PostPosted: Tue Apr 11, 2006 7:12 am     Reply with quote
Look in the manual. Do a search on the keyword 'stream'. Alternatively do a search here on the same word.
Remember though the limitations of a 'software' serial (which is what will be used on any pins except the hardware UART ones).
